There are reports from knowing users early after X Plus release full BW is from 580-620MHz , why do we need confirm this again ? ![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
Because when I first did the "improvement" using the
MSCP MCBD command to install the 500MHz license out of the box the best I could get (using a sine wave generator) was 266MHz and there was quite a bit of distortion on the rising edge of the signal in the form of a much slower rise time on the 2nd half of the rising edge. The model ID was changed to SDS2504X Plus but it was NOT running at 500MHz.
I then used the
MSCP MCBD command to put it back to 100MHz and then installed the licenses 200 -> 350 -> 500 using the UI and now I'm getting better than 600MHz.
I think the 500MHz license makes certain adjustments but not all of them. It requires the scope to be already at 350MHz.
So .. my plan is to get in front of the SW generator again, put it back to 100MHz, do the direct to 500MHz
MSCP MCBD command and see what I get. If it's the same as last time, then I'll take a screen shot. Then I'll do the 100 -> 200 -> 350 -> 500 again and run a series and let everyone know the results.
Maybe folks that are doing the 500MHz directly with the
MSCP MCBD command are not getting what they think. I know bingo600 did it through the UI .. he's getting good results and when I did it through the UI I got better results.
Besides, this is fun.
