Author Topic: Siglent SDS2000X Plus  (Read 946909 times)
Offline KungFuJosh
  • TEAS is real.
Re: Siglent SDS2000X Plus
« Reply #4575 on: August 17, 2024, 06:17:57 pm »
Did you put the unzipped recovery files in the root of the USB stick?
Offline giovannirat
  • Country: at
« Reply #4576 on: August 17, 2024, 06:29:17 pm »
The file I've got was not zipped, it was a xxxx.ADS file and I've put this in the root of the USB stick.
Offline KungFuJosh
  • TEAS is real.
« Reply #4577 on: August 17, 2024, 06:39:41 pm »
ADS files are firmware files that get upgraded via the system menu in the scope.
If you're using a recovery package that operates during boot, it will not be an ADS file. The version I had was 4 files, none of which were ADS.
Offline giovannirat
  • Country: at
« Reply #4578 on: August 17, 2024, 06:52:14 pm »
That's interesting....
The file provided from Rob was "SDS2000X+_HELP_UPGRADE.ADS", on the other hand he mentioned in his instructions ""..place files..."
So you may be right and he sent the wrong link.
Thank you very much...
« Last Edit: August 17, 2024, 06:53:49 pm by giovannirat »
Online tautechTopic starter
« Reply #4579 on: August 17, 2024, 09:10:59 pm »
We have an updated recovery package now so I'll flick it to you soon.
The following users thanked this post: bingo600
Offline bingo600
« Reply #4580 on: August 18, 2024, 06:23:41 am »
Same here
@tautech
Will you resend to the full "BCC" list ?
« Last Edit: August 18, 2024, 06:30:36 am by bingo600 »
Offline Peter_O
« Reply #4581 on: August 18, 2024, 08:07:35 am »
There are two different patch sets:
One is the single ADS file.
The other is a set of files, none of which is ADS.
Tautech can say for sure what to use in your specific case.
« Reply #4582 on: August 18, 2024, 09:06:16 am »
This is the latest Uboot fix.  ;)
May or may not require latest FW install afterwards.....
Offline idolclub
« Reply #4583 on: August 28, 2024, 12:04:36 pm »
SDS2000X Plus Operating System_V5.4.0 (Release Date 08.27.24 )
Revision History
2024/08/21    5.4.0     Support time zone setting.
2020/04/17    5.0.0     Initial formal release.
Download:
https://siglentna.com/download/44461/?tmstv=1724836595
The following users thanked this post: KeBeNe, tautech, KungFuJosh, Deichgraf, mathstudi, Wrenches of Death, symphonystars
« Reply #4584 on: August 29, 2024, 12:44:08 am »
Revision History
Download:
Thanks, can also be found near the bottom of the page here:
https://int.siglent.com/download/firmwares/?ProId=53
Offline chostetler
« Reply #4585 on: August 30, 2024, 01:43:56 pm »
I saw a joke earlier in this thread about screen protectors and bubbles. Just received my scope from Saelig and I removed the screen film installed at the factory that had a red tab and said remove before use. However, my screen seems to have another film installed on it and in this one I have bubbles.
Is there a second protective film that needs to be removed or do I have an issue with my screen?
See photos. Scope is brand new just opened.
I received my in middle of 12/2022 and it had the same issue. At first I thought it’s defective display, but shortly I realized it’s 2nd layer.
I used toothpick to remove it.
Adding on to this with another new scope with the same issue. This one was from TEquipment. Attached picture is before I removed the film.  Maybe this is a factory film for the display that Siglent forgot to remove?  :-// Anyway, I just peeled it off like MarkusAJ suggested and now it looks great!
Offline Oberot
  • Country: ru
« Reply #4586 on: August 31, 2024, 05:02:31 am »
Hi all
After updating to a new OS, a problem appeared.
My scope is a localized version of Siglent for my country, All updates were installed from the official Siglent website and had no problems. https://www.siglenteu.com/service-and-support/firmware-software/digital-oscilloscopes/#sds2000x-plus
After the update OS, similar artifacts appeared in the scope menu, I also noticed some slowness in operation. How can I fix this?
« Reply #4587 on: August 31, 2024, 05:07:21 am »
The following users thanked this post: Markus2801A, Oberot
Offline Oberot
  • Country: ru
« Reply #4588 on: August 31, 2024, 05:40:39 am »
Thanks tautech, everything worked
