The file I've got was not zipped, it was a xxxx.ADS file and I've put this in the root of the USB stick.
That's interesting....The file provided from Rob was "SDS2000X+_HELP_UPGRADE.ADS", on the other hand he mentioned in his instructions ""..place files..." So you may be right and he sent the wrong link.Thank you very much...
There are two different patch sets:One is the single ADS file.The other is a set of files, none of which is ADS.Tautech can say for sure what to use in your specific case.
SDS2000X Plus Operating System_V5.4.0 (Release Date 08.27.24 )Revision History2024/08/21 5.4.0 Support time zone setting.2020/04/17 5.0.0 Initial formal release.Download:https://siglentna.com/download/44461/?tmstv=1724836595
Quote from: TakeItApart on March 19, 2023, 12:12:44 amI saw a joke earlier in this thread about screen protectors and bubbles. Just received my scope from Saelig and I removed the screen film installed at the factory that had a red tab and said remove before use. However, my screen seems to have another film installed on it and in this one I have bubbles. Is there a second protective film that needs to be removed or do I have an issue with my screen?See photos. Scope is brand new just opened.I received my in middle of 12/2022 and it had the same issue. At first I thought it’s defective display, but shortly I realized it’s 2nd layer.I used toothpick to remove it.
