There is a saying:
If it's not broken, DON'T FIX IT!
I can't help myself, but mostly that's ME. ![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
Problem is, it IS broken.
The video trigger doesn't see the difference between fields, the line counter doesn't work properly and there is a lot of jitter. Oh, and there is no clamp function to help the trigger setpoint, making triggering a pain in the
![WTF? :wtf:](https://www.eevblog.com/forum/Smileys/default/wtf2.gif)
Just the basic stuff that doesn't work
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
(and yes on my trusty old Tek TDS2204c this does work properly, I just hate having to change scopes).
Revision Record Date Version Revision
3/28/2024
1.6.2R1
1. Added new Analysis function: Serial Signal Test (Analysis | Serial Signal Test)
2. Optimized UI
3. Supported USB-GPIB adapter
4. Fixed several bugs
a) "Bended" / "tilted" trace at small V/div
b) Math: Filter sample rate adaption cannot work
c) Frequency / Period measurements fail on certain waveforms
No mention of any fix of the broken video trigger option. I'll just wait.
