I still can't get the Bode plot working. I have my SDG hooked up over USB and it tests OK, I set both SDG CH's to 50 Ohm, and both on the scope to 50, and 1x, before selecting CH coupling, and on the scope going into BP.
My DUT is certainly not 50 ohm's anything, it's a differential mixer, I worked out the output impedance, it's not 50 of course. But I'm not entering it's transfer function into my scope.
You can see my settings below, I have a BNC M2M from CH1 to CH1, and a BNC to alligator clip from AWG CH2 to an input cap of the mixer. And the output is right on the output collector, with another BNC to alligator clip, from scope CH3. That cable might be a bit dodgy, I'll swap them and see if I can find another one.
I had the scope set to AC coupling, so no output cap on the collector, shouldn't matter.
But shouldn't that be working, without me using external terminators, or feed through terminators ? I'm getting more used to the names of all this stuff, but just trying to buy some good cables today on Digikey, IDK what else I really need for just the Bode Plot.
I have an RF textbook that's ok, there's lot's in there on coax and transmission lines, plenty to do there, but I expected the Bode plot to work, IDK what I'm over looking still.
Also on a legit site like Digikey, what's the difference between a $3 1GHz 50 terminator, and a $20 one ?? Maybe some other numbers, but will one wear out way quicker I wonder ? Same with BNC RG-58 cables, are the cheapest models on Digikey, just going to break in a few months or 1-2 years of normal use ?
