Author Topic: Siglent SDS2000X Plus  (Read 938694 times)
0 Members and 12 Guests are viewing this topic.
Online tautechTopic starter
Re: Siglent SDS2000X Plus
« Reply #3925 on: December 09, 2022, 10:02:30 pm »
@Tautech
Would you please ask Siglent to get telnet (or ssh) back with future firmware releases? As said by others, it can be useful.
Thanks.
What for ?  :-//
Cannot think about any usage case, right now.
Good, please keep it that way as there is absolutely no need to venture into the innards of the DSO !
That's been all done before and there are no further answers any of us need.
If you are passionate about electronics, I'd say you should feel a compelling force that drives you toward tinkering with stuff, regardless of the actual benefit  :popcorn:
The only benefits I see are not and actually just more work helping souls in despair that have messed with the OS and bricked the instrument for which they then need our help to recover.  :horse:
Those that really know what they're doing don't need no darn open port to get into an instrument.  :popcorn:
So after all the waffling today have you installed the latest firmware yet ? You should. The Timezone bug is a nothing and can be worked around with setting a UTC zone.
Offline balnazzar
« Reply #3926 on: December 09, 2022, 10:05:32 pm »
Listen, I just updated the firmware.. Now, if you click on "file converter" on the web interface, it lets you download a file converter (wow!), in .zip format.
When you unzip it, it shows two files. A windows' .exe (the converter's executable), and a Readme text file. The Readme says:
"We provide two tools to convert bin file into csv file:Bin2csv.exe and Convert_bin_to_csv_file.py [etc, etc..]"
There is no python script. I'd like to have it.
Is it the same for y'all? No python converter in the .zip file??
Thanks.
« Last Edit: December 09, 2022, 10:08:17 pm by balnazzar »
Offline balnazzar
« Reply #3927 on: December 09, 2022, 10:07:25 pm »
I just did! See my other complaints above ^-^
Seriously, I understand Siglent not wanting the customer to mess with the OS. And yet....
« Reply #3928 on: December 09, 2022, 10:13:09 pm »
Run/install Bin2csv.exe on your PC.....then you get options of how to manage the downloaded from DSO BIN files....you know those ones much smaller than CSV.
Offline Martin72
  • Testfield Technician
« Reply #3929 on: December 09, 2022, 10:13:48 pm »
Until the bug will be fixed, shouldn´t last long.
(Kierkegaard)
« Reply #3930 on: December 09, 2022, 10:19:45 pm »
Guess is ~Chinese New Year, some 8-9 weeks away.
Normally a lot of FW updates are released then.
Offline Martin72
« Reply #3931 on: December 09, 2022, 10:27:16 pm »
I´m curious about the next (second) HD update, but that´s an other topic.
(Kierkegaard)
Offline balnazzar
« Reply #3932 on: December 10, 2022, 07:15:53 pm »
Thing is that the .exe is windows only, while a .py would have been cross platform, and embeddable.
Would you please check if it's absent in your 2kX+(s) too?
Offline BillyO
« Reply #3933 on: December 10, 2022, 07:33:30 pm »
I also only get the Windows executable.
« Reply #3934 on: December 10, 2022, 08:16:16 pm »
So you sourced your copy from the webserver button, correct.
Have a look in the scopes Save/Recall menu too or in File Manager.
Will have a hunt soon.
Offline Peter_O
« Reply #3935 on: December 10, 2022, 08:33:31 pm »
Calibrating my HP3310A, I have just thought about:
How can I measure THD with a SDS2000X+?
Would have expected this as measurement of source  F1=FFT.   :-//
My HP35665A just shows the value in %.
« Last Edit: December 10, 2022, 09:04:10 pm by Peter_O »
The following users thanked this post: Markus2801A
Offline Martin72
« Reply #3936 on: December 10, 2022, 08:53:41 pm »
This would be a huge effort when e.g. the table could present at the end the THD.
Actually there´s no alternative from counting the shds together.
When one of our tested inverter shows a suspicious THD on the analyzer, we connect a scope at the output and watching the shds on the FFT screen.
Table function allows you to display the shds in numeric form, as mentioned above it would be cool if the scope would display the thd also.
EDIT:
http://www.sengpielaudio.com/calculator-thd.htm
THD table, calculator
« Last Edit: December 10, 2022, 08:55:29 pm by Martin72 »
(Kierkegaard)
The following users thanked this post: Markus2801A, Peter_O
Offline Deichgraf
« Reply #3937 on: December 10, 2022, 09:53:57 pm »
Also for me, no python script in the zip.
« Reply #3938 on: December 10, 2022, 10:07:01 pm »
This looks not bad and available in Windoze, Mac and Linux versions:
https://www.liquidinstruments.com/resources/update-log/li-file-converter/
Tell me how it goes and if any good will add it to the POI list.
The following users thanked this post: balnazzar
Offline blurpy
  • Country: no
« Reply #3939 on: December 11, 2022, 11:34:32 am »
It supports THD calculation in power analysis mode, so I asked a while ago if this could be added to the regular FFT as well:
https://www.eevblog.com/forum/testgear/siglent-sds2000x-plus-bugs-missing-features-feature-requests/msg3625265/?topicseen#msg3625265
No dice  :-\
The following users thanked this post: Martin72, Markus2801A
Offline Martin72
« Reply #3940 on: December 11, 2022, 11:38:03 am »
Ahhh..
We should set it again on the wishlist, it´s one of the "most useful" wishes IMHO..
(Kierkegaard)
The following users thanked this post: Markus2801A, blurpy
Offline balnazzar
« Reply #3942 on: December 11, 2022, 12:52:13 pm »
It seems to work, thanks (tested with just one file though)
Offline Peter_O
« Reply #3943 on: December 11, 2022, 05:10:36 pm »
Just linked this in another thread for Peter:
https://www.researchgate.net/publication/362542224_Total_Harmonic_Distortion_THD_analysis_utilizing_the_FFT_capabilities_of_modern_digital_storage_oscilloscopes
Thats a nice comprehensive paper, Rob, thx!
I did the adjustment by just minimizing the peak levels of the harmonics.
Before and after the adjustment.
1660474-0" alt="" width="300" class="bbc_img resized" />
Minimal tweaks of the two potis involved gave a nice improvement.
The manual of the 3310A just stated a "Distortion" of better than 46dB below the main signal.
As they suggest a HP331A for the distortion measurement, I checked that manual. The 331 just filters away the main frequency and offers the remaining signal to RMS measurement.
Will have to read the paper above first to think about a valid calculation.
Or did I miss a sophisticated filter funtion of the SDS2000x+?
« Last Edit: December 11, 2022, 05:12:35 pm by Peter_O »
« Reply #3944 on: December 11, 2022, 06:46:25 pm »
(Attachment Link) " alt="" width="300" class="bbc_img resized" />
Or did I miss a sophisticated filter function of the SDS2000x+?
I was thinking you might be able to use the Math Equation editor to build some THD analysis formula.
Please don't ask for guidance as my algebra is abismal.  :palm:
Offline Martin72
« Reply #3945 on: December 11, 2022, 08:51:18 pm »
Can´t imagine you can calculate this via editor, for THD you must summarize all SHDs, how can you determine them separately from the FFT in the editor...
Way better would be an implementation directly in the FFT menu like it is in the PA.
(Kierkegaard)
Offline Peter_O
« Reply #3946 on: December 12, 2022, 09:42:43 am »
Haven't played yet, but: Can I get the peak list exported, e.g. zu CSV? Then it would be easy in xls.
Edit: Now I have played:
I found no option to chose the part of screen content to export.
CSV export starts like this and delivers 524.300k records, intro included.
FFT Length,1048576
Record Length,524288
FFT Sample Rate,+2.000000E+07,
Delta Frequency,+1.907349E+01,
Start Frequency,+0.000000E+00,
Stop Frequency,+1.000000E+07,
Vertical Units,F1:,Real part,Vrms,Imaginary part,Vrms,Magnitude,dBV,
Model,SDS2504X Plus
Serial Number,SDS2[color=brown]xxxxxxxxxx[/color]
Software Version,5.0.1.5.2R1
SourceF1:
Frequency,Real part,Imaginary part,Magnitude,Angle
+0.000000E+00,-5.102248E-02,+0.000000E+00,-2.584477E+01,+3.141593E+00
+1.907349E+01,+3.603616E-02,-7.285543E-05,-2.886521E+01,-2.021729E-03
+3.814697E+01,+1.263447E-04,-6.157281E-05,-7.704340E+01,-4.534683E-01
+5.722046E+01,-1.235591E-04,+5.903102E-05,-7.726964E+01,+2.695899E+00
+7.629395E+01,+1.422552E-05,-6.032916E-05,-8.415446E+01,-1.339228E+00
No peak list export.  :-//
« Last Edit: December 12, 2022, 10:45:45 am by Peter_O »
« Reply #3947 on: December 12, 2022, 10:41:05 am »
IIRC you can save in BIN format, much smaller than CSV and download the internal BIN2CSV tool to convert the BIN file back to CSV.
Also in FFT you can use the Peak Hold but unsure how that effects the file capture.
Offline Peter_O
« Reply #3948 on: December 12, 2022, 10:46:13 am »
FFT Length,1048576
Model,SDS2504X Plus
Serial Number,SDS2xxxxxxxxxx
SourceF1:
Offline Peter_O
« Reply #3949 on: December 12, 2022, 11:12:35 am »
... and a question:
What is ths 'Para Switch' for in the Save menu?
CSV output seems to be identical on and off.
Edit: RTFMRM  :palm:  (... most recent ...):
>>CSV Data
Saves the waveform data to the external memory in ".csv" format. After
selecting this type, you can touch the ParaSwitch to determine to
include the scope configuration parameter information (horizontal
timebase, vertical scale, etc.) or not. Touch the Save All Channel to
save all displayed waveforms on the screen or select the Source to
save. The available sources include C1 ~ C4 and F1 ~ F2. <<
« Last Edit: December 12, 2022, 11:19:11 am by Peter_O »
