Oberot and 10 Guests are viewing this topic.
It comes with a screen protector, after all. BUT without caps for the BNCs! (The SDS5000s do have them!)Now the challenge: removing the warranty seal without breaking it , so that I can install the Noctua. Then, finding the right-sized screws so that I can assemble the VESA contraption as per Martin's recipe!
Question: Can you buy from Amazon (U.S.) and get the reduced price option bundle: “MSO with probe options and arbitrary generator for only $219. “ ?Answer: No. Direct from Siglent customer support:
I would never buy ANYTHING I care about through Amazon.
The "screen protector" is for shipping only. Remove it and toss it out.Enjoy your scope!
Quote from: BillyO on November 12, 2022, 04:17:30 amThe "screen protector" is for shipping only. Remove it and toss it out.Enjoy your scope!Oh woops Thank you for the tip, the screen looks great now!
Quote from: balnazzar on November 12, 2022, 01:05:40 amIt comes with a screen protector, after all. BUT without caps for the BNCs! (The SDS5000s do have them!)Now the challenge: removing the warranty seal without breaking it , so that I can install the Noctua. Then, finding the right-sized screws so that I can assemble the VESA contraption as per Martin's recipe!I remove the Siglent warranty seal all the time Little bit of heat from a hot air gun will loosen up the glue and let you peel the seal off with tweezers, without damaging it.
Would do only when the noise is really disturbing you.
Heat doesn't bode well for plastic...
Some of my local suppliers I support all the time sell through Amazon.
Why not buy from your local supplier directly? How can you claim to support them when you let Amazon take a cut of their income?
Do you mean the fan on the 1104x-e is louder?
So, by a just noticeable margin, the 1104 is louder.
Hi,Question to the new owners about the optionbundles/licenses.When you bought the scope with the bundle, are the licenses already installed or must you install them manually?Are they ready to use keys or must you generate them first?
Quote from: Martin72 on November 13, 2022, 11:54:52 pmAre they ready to use keys or must you generate them first?I asked mine to be rush shipped so it did not come with certificates or with them installed. I just used the key generator seeing as I was entitled.
Quote from: BillyO on November 14, 2022, 05:51:11 pmQuote from: Martin72 on November 13, 2022, 11:54:52 pmAre they ready to use keys or must you generate them first?I asked mine to be rush shipped so it did not come with certificates or with them installed. I just used the key generator seeing as I was entitled.So if you weren't entitled, you wouldn't have used it, right?
You have mail.
I just received my SDS2104X Plus from Saelig today! Quick question, did anyone else have air bubbles trapped under the screen protector on their units? There are quite a few air bubbles on mine, not exactly sure how to get rid of them...
