Author Topic: Siglent SDS2000X Plus  (Read 914383 times)
0 Members and 26 Guests are viewing this topic.
Offline TopQuark
  • Country: hk
Re: Siglent SDS2000X Plus
« Reply #3825 on: November 12, 2022, 01:15:14 am »
It comes with a screen protector, after all.  ::)  BUT without caps for the BNCs!  :-[ (The SDS5000s do have them!)
Now the challenge: removing the warranty seal without breaking it  >:D, so that I can install the Noctua. Then, finding the right-sized screws so that I can assemble the VESA contraption as per Martin's recipe!
I remove the Siglent warranty seal all the time  >:D  Little bit of heat from a hot air gun will loosen up the glue and let you peel the seal off with tweezers, without damaging it.
The following users thanked this post: balnazzar
Offline Martin72
  • Testfield Technician
« Reply #3826 on: November 12, 2022, 01:15:52 am »
The HD too... ;)
Heatgun and razorblade.. ;)
Would do only when the noise is really disturbing you.
(Kierkegaard)
Offline PortableFishy
« Reply #3827 on: November 12, 2022, 04:03:53 am »
I just received my SDS2104X Plus from Saelig today!  :D
Quick question, did anyone else have air bubbles trapped under the screen protector on their units? There are quite a few air bubbles on mine, not exactly sure how to get rid of them...
Offline BillyO
« Reply #3828 on: November 12, 2022, 04:17:30 am »
The "screen protector" is for shipping only.  Remove it and toss it out.
Enjoy your scope!
Want to see an old guy fumble around re-learning a career left 40 years ago?  Well, look no further .. https://www.youtube.com/@uni-byte
The following users thanked this post: PortableFishy, balnazzar
Offline Geoff-AU
« Reply #3829 on: November 12, 2022, 04:36:13 am »
Question:  Can you buy from Amazon (U.S.) and get the reduced price option bundle: “MSO with probe options and arbitrary generator for only $219. “ ?
Answer:  No.  Direct from Siglent customer support:
I would never buy ANYTHING I care about through Amazon.
The following users thanked this post: tautech, sbrom, Johnny B Good
Offline BillyO
« Reply #3830 on: November 12, 2022, 04:48:10 am »
Oh, don't be silly.
I care about everything I get through Amazon.  I'm just more particular about who the vendor is as the price goes up.
Some of my local suppliers I support all the time sell through Amazon.
What, precisely, do you have against the platform?  Does the fact you can return anything for the slightest reason piss you off?
« Reply #3831 on: November 12, 2022, 04:52:40 am »
Enjoy your scope!
Oh woops  ;D
Thank you for the tip, the screen looks great now!
Offline tautechTopic starter
« Reply #3832 on: November 12, 2022, 05:12:04 am »
Enjoy your scope!
Oh woops  ;D
Yep, now only Siglent touch screen devices come with a display overlay whereas once everything did.
Up to you but you drive the scope mostly with a mouse and the front panel controls but everyone seems to have their own style it seems.
I visited Defpom this week and left him some gear to review and he had a quick play with our SDS6204A and as its UI is very similar to his SDS2104X Plus he was quite at home with it but had developed his own style and drove it in ways I don't.  :o
Enjoy your new scope.
Offline balnazzar
« Reply #3833 on: November 12, 2022, 01:27:27 pm »
One needs to be careful with the air gun, and I don't have much experience. Heat doesn't bode well for plastic...
« Last Edit: November 12, 2022, 01:35:05 pm by balnazzar »
Offline balnazzar
« Reply #3834 on: November 12, 2022, 01:30:16 pm »
Well, contrarily to the 1104x-e, this fan doesn't exhibit a particularly annoying aerodynamic noise (being 92 vs 60mm). The noise, strangely enough, comes from its motor. It's kind of a buzzzzzz...
Offline Martin72
« Reply #3835 on: November 12, 2022, 01:50:31 pm »
Must be a regulated heatgun, of course..
Maximum 80° and then heating the seal, carefully lift it up at the same time with a blade or similar very thin material.
(Kierkegaard)
Online Johnny B Good
« Reply #3836 on: November 12, 2022, 03:59:04 pm »
Enjoy your scope!
 Adding to that sage advice that this is best done  s l o w l y  to minimise the risk of ESD in very low humidity environments.
« Last Edit: November 12, 2022, 04:02:20 pm by Johnny B Good »
John
Offline Geoff-AU
« Reply #3837 on: November 13, 2022, 11:21:38 am »
Why not buy from your local supplier directly?  How can you claim to support them when you let Amazon take a cut of their income?
The following users thanked this post: Johnny B Good, pope
Offline pope
« Reply #3838 on: November 13, 2022, 02:09:09 pm »
Do you mean the fan on the 1104x-e is louder?
Offline BillyO
« Reply #3839 on: November 13, 2022, 03:19:15 pm »
I do buy direct from them.  Who said I didn't?  Or are you just making contrary assumptions to be argumentative?
My point is, reputable people sell through Amazon - and will support their products.  You can check who the seller is before you buy and make your decision to buy or not.
In any case, Amazon Canada do stock and sell some Siglent products.  The SDS1104X-E is an example and Siglent NA supplies them to Amazon and will support them.
Offline BillyO
« Reply #3840 on: November 13, 2022, 03:23:27 pm »
I have both.  I'll test them today.
Edit:  They are both about the same.  Measured (C weighting, fast response) one meter in front of each scope the SDS2104X+ is 38dB, the SDS1104X-E is 40dB.
So, by a just noticeable margin, the 1104 is louder.
« Last Edit: November 13, 2022, 03:41:54 pm by BillyO »
The following users thanked this post: pope
Offline balnazzar
« Reply #3841 on: November 13, 2022, 08:00:39 pm »
Yes. Louder, and higher-pitched too.
Offline balnazzar
« Reply #3842 on: November 13, 2022, 08:03:51 pm »
Don't forget the pitch, it makes a lot of difference along with those 2 dBs.
I'll put a noctua into my 2K+, but I could even live with its stock fan. With 1104x-e's fan, I definitely couldn't have..
Offline Martin72
« Reply #3843 on: November 13, 2022, 11:54:52 pm »
Question to the new owners about the optionbundles/licenses.
When you bought the scope with the bundle, are the licenses already installed or must you install them manually?
Are they ready to use keys or must you generate them first?
(Kierkegaard)
Offline balnazzar
« Reply #3844 on: November 14, 2022, 02:45:39 pm »
You have to install it by yourself. Batterfly sent me the certificates by e-mail too. Until now, I have not installed anything yet (nor I tried to hack the scope or even read through the hacking thread) because I have zero spare time this week...
It's worth noting that all the options do have a 30-day trial enabled by default.
Offline BillyO
« Reply #3845 on: November 14, 2022, 05:51:11 pm »
I asked mine to be rush shipped so it did not come with certificates or with them installed.  I just used the key generator seeing as I was entitled.
Offline balnazzar
« Reply #3846 on: November 14, 2022, 06:20:29 pm »
So if you weren't entitled, you wouldn't have used it, right?  >:D ^-^
« Reply #3847 on: November 14, 2022, 06:42:41 pm »
;D
You have mail.
Offline BillyO
« Reply #3848 on: November 14, 2022, 07:16:55 pm »
You have mail.
I even have e-mail!
I should go ahead and request them just to have them.
The thing is, when I did it myself, I just kept going until the key gen went "click!"
Offline gtube
« Reply #3849 on: November 14, 2022, 07:45:17 pm »
You can get a tempered glass screen protector here:
https://www.aliexpress.com/item/1000008551527.html?spm=a2g0o.order_list.0.0.312f1802LRoG9y
