While in arbitrary generators, be it Rigol or Siglent, I have to admit that encoders are a tragedy. It is in oscilloscopes that it seems to me that this is a user's problem. Who spin the encoders left and right so fast that they don't seem to see for themselves what exactly they want to set ![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
Certainly not people who are using scopes that can't keep up with their commands!
![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
Just like with typing text into the computer, the way you give command sequences to a device will depend on your experience with that device. If it tends to drop commands on the floor then you're going to take your time to be certain that it lands in the state you want it to. You
won't trust the device to do the right thing. Similarly, if your computer tends to drop letters that you type on the floor, you're going to be very careful with typing to make sure that what you've typed shows up properly. If, on the other hand, your experience is that it reliably obeys your command sequences then you'll learn to relax your oversight of it.
That may or may not be a good thing, depending on the likelihood of error on its part and the importance of exactly the right settings.
Either way, the point here is that these devices are so incredibly fast compared to humans that there's really no good reason for them to not be able to keep up with human inputs. Our inputs are
glacial to them. That means that failure of the device to keep up with human commands to it is an
architectural defect, plain and simple.
I even recorded a video with a comparison of Rigol's oscilloscopes once, because on a certain Polish forum there were similar accusations about slow operation. Personally, I try to take my time with measurements as this often leads to very costly errors... With this approach to measurements, the problem is not felt ![Popcorn :popcorn:](https://www.eevblog.com/forum/Smileys/default/EatingPopcorn.jpg)
Of course. But then at the same time, you're forced to spend more time on setting up the instrument than you might otherwise. Not an enormous amount of difference, mind you, but an instrument that reliably obeys your commands is one that allows you to turn your attention to higher level things.
For the Siglent, how usable the scope is with respect to making changes to the settings depends on what it's doing. Turning on the FFT will seriously compromise its responsiveness when you operate the controls, for instance. It's not the end of the world or anything, of course.
Those here who are skeptical of the value of a highly responsive user interface in a scope should try using an Instek scope or, especially, a Keysight scope. The Instek is very fast. The Keysight is instantaneous. It's only when you go back to a slower scope that you realize just how unresponsive the slower scope really is.
We tend to be very capable of adapting to the demands of different equipment. That works in our favor, but does not diminish the value of a fast UI.
If you want to really see the value of a fast UI, I have a suggestion: keep your computer on 24x7, install and use Firefox, and keep Firefox open for as long as you can stand. You'll find that it tends to get slower over time, perhaps to the point of frustration. That frustration is
proof that you value a fast UI. And if you value a fast UI in a computer, why don't you similarly value one in a scope, or anything else that you interact with?
