Sorry guys, I was busy..
I unfortunately don't have SDS2000X+, only that SDS6104H12 to try.
And also can try on one scope similar to 2000X+ but higher res ....
I'm not sure if any of those two behave exactly as SDS2000X+.
If you guys enable Averaging as an Acquisition mode, then scope will interpolate more points...
Try that. On both ones I have here it increased apparent sample rate for FFT..
Also gf is right.
There is "interpolate" math function, that it would be simpler if it was called "upsample".
It resamples current samples to higher sample rate by interpolating from real data. I guess name comes from that.
On that "scope similar to sds2000X+" I can upsample by factor of 20X.
So if you use Averaging acquisition mode, and math formula FFT(d(Interpolate(C1))/dt) with interpolate 20X I get this:
SDS6000H12 with it's 5GS/s seems to have sample rate high enough by default... But even with it this method helps..
