them SP2035 probes !!
it has been up quite a few times before, BUT now I wanted to solve it, once and for all,
it is possible to take apart the tip, and the metal part out, now press a little bit , see red arrow, now the metal is in contact with the scope tip.
I also added glue to make it more easy to use.
The BNC end : the 6 gnd blades are normally supposed to be a bit springy, they are not like that at all,
so the connector body is way to loose and with unstable gnd contact with the scope, carefully bend all 6 blades out
only as little as it is barely visible you did it, now feel how much better the connector mate with scope,
and note your measurements are nice and stable.
