Author Topic: Siglent SDS2000X Plus  (Read 914369 times)
0 Members and 19 Guests are viewing this topic.
Offline Martin72
  • Testfield Technician
Re: Siglent SDS2000X Plus
« Reply #2950 on: November 07, 2021, 10:00:46 am »
Further things done...
Marked and drilled holes and paying attention, not to leave any metal chips over.
Also I´ve done the mounting with polyester screws/nuts only.
I think, it will be finished today.
To be continued..
(Kierkegaard)
The following users thanked this post: Coder69, Bad_Driver, artik
Offline Martin72
« Reply #2951 on: November 07, 2021, 11:41:01 am »
Finally it´s done...
No need to cut off the connector from the original fan when you got the preciva crimp set... 8)
Reassembling the unit and turning it on - It works and.....silence is golden.. ;D
This solution is probably one of the best, but my warranty is now lost.
Other no warranty lost solution:
-Make your own connection cable as described before, so you could change back to the original fan without leaving any traces..
-Warm up the warranty-sign before open the case...
-Take the LNA (Deichgrafs post) instead of adding a pcb to reduce fan speed...
Martin
« Last Edit: November 07, 2021, 11:50:46 am by Martin72 »
(Kierkegaard)
The following users thanked this post: tv84, tubularnut, Coder69, blurpy, Bad_Driver, Deichgraf, artik
Offline Deichgraf
« Reply #2952 on: November 07, 2021, 11:50:40 am »
Hi Martin,
good work and if I had a clue about the preciva cimp set ...
So you used also a NTC temperature probe to control fan RPM depending on how hot it is in the box?
Regards
Offline Martin72
« Reply #2953 on: November 07, 2021, 04:05:02 pm »
Hi Deichgraf,
Thankyou and yes, the ntc is part of the speed controlling, according to the DIP switches.
Me I thought, I´ve switched it to 40°C but it seems the fan is running at full speed from the beginning, so I must check it again - Although and even at this speed the noctua fan is remarkable quiter than the original. 8)
Last year I´ve bought this complete set on https://www.amazon.de/Crimpzange-Dupont-Stecker-Steckverbinder-Crimpkontakten/dp/B07QX51F3B/ref=sr_1_4?__mk_de_DE=%C3%85M%C3%85%C5%BD%C3%95%C3%91&keywords=preciva+crimpzange+set&qid=1636314038&sr=8-4]Amazon
It works well, didn´t regret it so far.
Martin
« Last Edit: November 07, 2021, 07:43:34 pm by Martin72 »
(Kierkegaard)
The following users thanked this post: Coder69, Deichgraf
Offline Martin72
« Reply #2954 on: November 07, 2021, 06:32:50 pm »
I´ve bought the fan controller on amazon and as "always", there´s no manual avaible.. :P
But thank god, someone in the world wide web checked this controller before:
https://www.electroschematics.com/fan-speed-controller/
Ah, now everything seems clearer.... ;D
After done the settings you can´t hear a damn thing, very nice...
Martin
« Last Edit: November 07, 2021, 06:45:42 pm by Martin72 »
(Kierkegaard)
The following users thanked this post: wolfy007, artik
Offline steve1515
« Reply #2955 on: November 07, 2021, 08:07:45 pm »
Does anyone have a link to the ADS file to enable telnet for the SDS2000X+ on the latest firmware? I can't seem to find it anywhere.
Offline tautechTopic starter
« Reply #2956 on: November 07, 2021, 08:10:42 pm »
Last I checked there was no need to go poking into the OS on these when the online scripts work just fine.
Offline steve1515
« Reply #2957 on: November 07, 2021, 08:16:08 pm »
For normal purposes, you are correct. I'm just looking to do a little investigative research.  ;)
Offline hj
The following users thanked this post: steve1515, Deichgraf
Offline wdbarker3
« Reply #2959 on: November 08, 2021, 02:25:52 pm »
10/21/2021 - 1.3.9R6 - Wrong FFT frequency when memory depth > 10 Mpts
FIXED! Yea!
The following users thanked this post: Johnny B Good
Offline jemangedeslolos
« Reply #2960 on: November 10, 2021, 11:24:40 am »
Hello :)
Do you know what are the differences between the different hardware version ?
I noticed at least two versions : 02-00 and 02-04
If it hasn't been discussed yet, I'm curious to know what subject these differences play on ?
Offline NCG
  • Country: ee
« Reply #2961 on: November 12, 2021, 02:48:18 am »
There is third pin place on scope board and I think there was something for fan speed when exploring the conf files, maybe it works only with SDS5000 though. Might be worth going over.
Offline oz2cpu
    • webx.dk private hobby and diy stuff
« Reply #2962 on: November 13, 2021, 02:14:11 pm »
them SP2035 probes !!
it has been up quite a few times before, BUT now I wanted to solve it, once and for all,
it is possible to take apart the tip, and the metal part out, now press a little bit , see red arrow, now the metal is in contact with the scope tip.
I also added glue to make it more easy to use.
The BNC end : the 6 gnd blades are normally supposed to be a bit springy, they are not like that at all,
so the connector body is way to loose and with unstable gnd contact with the scope, carefully bend all 6 blades out
only as little as it is barely visible you did it, now feel how much better the connector mate with scope,
and note your measurements are nice and stable.
Radioamateur OZ2CPU, Senior EE at Prevas
EMC RF SMPS SI PCB LAYOUT and all that stuff.
youtube : oz2cpu teardown
The following users thanked this post: Bad_Driver, Deichgraf
Offline dannytt
« Reply #2963 on: November 17, 2021, 02:27:01 am »
hello everyone... i just got my SDS2074X Plus, base on old post i make it to 500MhZ ..... only the SDS-2000-FG cant use... anyone can tell me how to active it? many many thx.
« Reply #2964 on: November 17, 2021, 03:17:32 am »
Search works just fine:
https://www.eevblog.com/forum/testgear/siglent-sds2000x-plus-hack/
Offline dannytt
« Reply #2965 on: November 17, 2021, 04:43:33 am »
i have tried it many times... but all not working...  only the FG part not work other all fine
Offline Bad_Driver
« Reply #2966 on: November 18, 2021, 06:51:35 am »
Very very simple. You have to use the FG at least one time in the test/free mode before you can enter
the serial number. I spend a nice afternoon with increasing frustration since it was the first license
I tried to enter and I thought the whole improvement process wont‘t work with my device.
« Last Edit: November 18, 2021, 01:12:56 pm by Bad_Driver »
The following users thanked this post: oz2cpu
Offline dannytt
« Reply #2967 on: November 19, 2021, 07:12:49 am »
can u tell me which i key gen i should use? since i tried ur method but....
« Reply #2968 on: November 19, 2021, 08:03:30 am »
Option codes are always lowercase.
Offline Garga
  • Country: hu
« Reply #2969 on: November 19, 2021, 08:14:04 am »
Hi Performa01!
https://www.eevblog.com/forum/testgear/siglent-sds2000x-plus-coming/msg3782555/#msg3782555
I am very happy with this topic! 😊
I would like to use it for sound frequency measurement (FFT).
If fed with a lower distortion 1kHz generator, would much smaller distortion values be measurable?
For example:
-80dBv THD 0.01%
-90dBv THD 0.00316%
-100dBv THD 0.001% 😊
Regards Garga
« Last Edit: November 19, 2021, 08:16:27 am by Garga »
Online Performa01
  • Country: at
« Reply #2970 on: November 19, 2021, 08:40:51 am »
Hi Garga,
sorry, but you cannot use an 8 bit system to measure very low distortion levels.
With appropriate dither or an auxiliary signal, the dynamic range could be stretched up to some 70 dB, that means 0.03% theoretically. But it's tricky.
For distortion measurements, I use a Picotech 4262 DSO, as this provides 96 dB dynamic range already without any tricks.
The following users thanked this post: egonotto, Deichgraf
Offline dannytt
« Reply #2971 on: November 19, 2021, 09:07:16 am »
o thx very very much. thx everyone which helped me...
Offline piramida
  • Country: ua
« Reply #2972 on: November 19, 2021, 09:09:41 am »
To measure distortion, you can use a notch filter to "cut" the first harmonic.
This scope is confused by a bandwidth of only 5 MHz.
A 5000 series picoscope with switchable vertical resolution ADC is not suitable for this purpose?
« Last Edit: November 19, 2021, 10:23:30 am by piramida »
Offline Martin72
« Reply #2973 on: November 19, 2021, 11:27:50 am »
Should be more than enough when measuring distortions in music-range up to 20khz.
But we´re going out of topic here.. ;)
(Kierkegaard)
Offline piramida
  • Country: ua
« Reply #2974 on: November 19, 2021, 11:54:21 am »
It turns out that one device is needed to measure distortion, and to see, for example, the self-excitation of an electronic circuit at tens of megahertz, another device is needed ... :(
