There is more than just graticule, touch display then menu and fiddle with the settings for backlight, intensity, graticule, etc till you find something you like
Although I have noticed the same thing you are talking about from when i had it on a higher shelf before I had the spot prepared at eye level for it.. it works best at eye level if you are able to do it
Have you tried increasing the graticule brightness?
JBG
Yep, I tried all the settings, everything is on max. dimming them doesn't help either...
I can't lower the shelf any more unfortunately... and I would need to lower it significantly anyway, which would make for a very low shelf haha. I checked out the screen a bit more thoroughly, you need to be dead center with the center of the screen, or above it. It's really funny/sad how the viewing angles when looking from above the screen are very good actually. Below it, it's really unforgiving. My eyes, at rest, are centered exactly on the channel inputs (where the cables go). So you can imagine that I am not that much off the screen.
I can put it on the bench itself but it's kind of awkward.
I did a very short test of some waveforms, they seemed ok.I'll do some more tests tomorrow. It's the font and grid and graticules (especially the horizontal ones, don't remember what you call those) that fade away. The text looks weird, kinda like dithered?
It's a shame because the screen is really nice when you are centered on it. Crisp and bright.
And it does really benefit from a dark room.
Really weird, I have seen plenty of TFT screens on rack equipment and they are not that demanding with the viewing angles.
