Author Topic: Siglent SDS2000X Plus  (Read 904709 times)
Offline 2N3055
  • Country: hr
Re: Siglent SDS2000X Plus
« Reply #1550 on: July 11, 2020, 04:02:25 pm »
I agree with Dave. It is a horrible design with all the pastel colours and fake silver rings on the knobs. Looks more like a beautybox for a teenager girl (on a budget), than like a professional test equipment.  :--
If you don't like how it looks, well, then I recommend you should not call it out on a date or marry it... :-DD
The following users thanked this post: egonotto, Elasia, Martin72
Online Martin72
  • Testfield Technician
« Reply #1551 on: July 11, 2020, 04:15:24 pm »
YMMD  :-DD
(Kierkegaard)
Online Martin72
« Reply #1552 on: July 11, 2020, 05:20:41 pm »
As I said, it´s a matter of personal taste, but....
For me, the R&S got the best design, then siglent, then keysight, then rigol, then micsig, then tek.... 8)
(Kierkegaard)
The following users thanked this post: Bad_Driver
Online tautechTopic starter
« Reply #1553 on: July 11, 2020, 09:42:29 pm »
Until you've used one you will never know.  :P
The front panel design layout is better than SDS5kX with buttons better grouped that are less commonly used.
But a real shame it doesn't have the 3rd USB port like 5kX has.  :(
But Siglent have learnt from this and the SDS6kX Pro does better with 4 USB ports, 2 front, 2 rear but we won't see these models in the west for a while yet.  :(
Online Martin72
« Reply #1554 on: July 11, 2020, 09:47:15 pm »
Disagree... ;)
One for the mouse, the second for the stick, it´s enough.....
(Kierkegaard)
« Reply #1555 on: July 11, 2020, 09:58:25 pm »
Disagree... ;)
Power STB3, current probe, charge phone.......  :P
Online Martin72
« Reply #1556 on: July 11, 2020, 10:00:07 pm »
.....external USB supply....
(Kierkegaard)
« Reply #1557 on: July 11, 2020, 10:06:57 pm »
I know.....I need use one sometimes just to take screenshots for you all here.
I love using the mouse with these new scopes but it hogs a USB port however with the 3 ports on 5kX it is not so much a problem.
Online Martin72
« Reply #1558 on: July 11, 2020, 10:15:13 pm »
Got a three port usb hub here, will test it on the siglent, if it´s work as expected on pc´s.
(Kierkegaard)
Offline Elasia
« Reply #1559 on: July 11, 2020, 10:41:10 pm »
I use a 3.0 hub on it.. works fine, remember its already a linux computer inside, its anything with a dedicated embedded processor that has been specialized to watch out for, not anything running on generalized hardware
Offline Elasia
« Reply #1560 on: July 11, 2020, 10:43:30 pm »
It works, isnt an eyesore, and no wasted space... i'd marry it
Although my favorite industrial designs tend to be R&S but they are big bucks usually
Online Martin72
« Reply #1561 on: July 11, 2020, 10:48:58 pm »
Same here....
If I got the money ( I got it, but not all for this hobby thing), I´ll spend it for an R&S scope.
But I couldn´t, so I spend it for the second best.... ;)
(Kierkegaard)
Online Martin72
« Reply #1562 on: July 12, 2020, 06:59:39 pm »
Yesterday my new sdg 1032, eh, 1062X arrived, today I wanted to measure the waveform update rate from my 2504X.
So I´ve connected the pass/fail/trigger out to the counter input.
Threshold setting to 1V.
Memdepth setting to minimum, feed in a 25Mhz signal and set the timebase for displaying one period.
And the counter counts....nothing.
Or something between 17...20Hz (when you disable measurings, it count´s nothing).
I wonder why it won´t function, this method I´ve used on my former rigol and it works exactly (500000Wfs....) like if you use a scope for.
Hmm...meanwhile I type this here, maybe 1V won´t fit.
Check that.
Edit:
That was it, setting to 1.5V and it works
« Last Edit: July 12, 2020, 07:06:37 pm by Martin72 »
(Kierkegaard)
Online Martin72
« Reply #1563 on: July 12, 2020, 08:24:08 pm »
Done a few measures.
Normal mode, the maximum wfs/s was 18961 on 5ns/div., sequential mode 50607 on the same timebase.
Dot/vector makes no difference.
Wfms/s was unstable in sequential mode, so I did a break after some measurings.
According to the specs, the maximum wfs/s should be 120000 in normal and 480000 in sequential mode.
I won´t say a thing, if the real values were something between 100000/normal and 400000/seq. .
But this values, if I done it correct, are poor and it seems to be a bug to be fixed.
(Kierkegaard)
The following users thanked this post: KeBeNe
Offline maginnovision
« Reply #1564 on: July 12, 2020, 08:28:41 pm »
What about less than 5ns?
Online Martin72
« Reply #1565 on: July 12, 2020, 08:33:05 pm »
You´re right, I´ve forgot the 2ns ( done the measure in such manner, that always one period of the signal fills the screen).
(Kierkegaard)
Offline TK
« Reply #1566 on: July 12, 2020, 08:41:55 pm »
I was saying the same for a long time, nobody paid attention.  Tautech said the spec was done by "Design Engineers".  Yeah, the design engineers wanted 120,000wfm/s, then R&D came up with 10% of spec.  It is not only the count, if you look at the signal with a scope, you will find some odd dead time in between.  I suspect it is measurement time, then if you activate statistics, the dead time increases significantly.
Online Martin72
« Reply #1567 on: July 12, 2020, 08:51:55 pm »
Yeah, to get the maximum value I must deactivate any measures.
8bit/10bit plays a role too and switching from fast to slow acquisition, this thing do it´s business... ;D
Nevertheless, in my opinion it´s too wide apart from the specs.
Done this as I said before with the rigol, it matches exactly the specs and more.
Also the trigger-signal from the rigol was so stable, that counter and scope measurings was equal.
So what´s going on with the siglent...
To be honest, that doesn´t worrying me in a matter, I would give it away.
But I find it remarkable enough to expect an official explanation for it.
Edit: Forwarded this to the siglent support.
« Last Edit: July 12, 2020, 09:17:28 pm by Martin72 »
(Kierkegaard)
Offline 0xdeadbeef
« Reply #1568 on: July 12, 2020, 09:18:12 pm »
Didn't we discuss this before and point mode is needed for maximum speed?
Online Martin72
« Reply #1569 on: July 12, 2020, 09:24:56 pm »
As I wrote it before, point/vector mode doesn´t take an effect - Maybe I´ve done something wrong, but this was the result.
Apart from this, i hope I got an answer/detailed explanation from siglent.
(Kierkegaard)
« Reply #1570 on: July 12, 2020, 09:28:58 pm »
To all, see how the master measures WFPS here:
https://www.eevblog.com/forum/testgear/siglent-sds1000x-series-oscilloscopes/msg1142108/#msg1142108
He has posted many Siglent WFPS tables over the years on most models and all meet spec !
There are certain operating conditions required to match datasheet results and some little thought is required to understand why.  ;)
Online Martin72
« Reply #1571 on: July 12, 2020, 09:42:55 pm »
Hehe... ;)
He should do this again with this model - As I said, maybe I did it not correctly, but missing the specs this way over is an indicator that something couldn´t be right.
And:
What´s the problem to describe in the specs under which circumstances these rates will be reached ?
So that everyone can measure it by.
As I wrote, rigol claims for the 5000 model update-rates up to 500000wfs/s and I could immediately proof this without any "tricks".
(Kierkegaard)
« Reply #1572 on: July 12, 2020, 09:53:36 pm »
Hehe... ;)
Notice his flag lately ?
Parked up on northern China waiting for this CV stuff to get under control in the EU....if it ever does.  :(
Study the charts, it's all there.  ;)
Tricks ?  :-// Optimal settings !
It is about knowing how to get the best from your instrument for the need at hand.
A very good example from another great post from rf-loop is here:
https://www.eevblog.com/forum/testgear/scope-wars/msg3121780/#msg3121780
Really really study it.  ;)
Online Martin72
« Reply #1573 on: July 12, 2020, 10:00:45 pm »
Another suggestion, show me how to do it.  ;)
Or show measures and then explain how you did it.
Or let´s waiting together what the support "says"..  8)
(Kierkegaard)
« Reply #1574 on: July 12, 2020, 10:11:25 pm »
Maybe in a few days when more Plus models are in stock and after I get backorders away.
You have the scope so use clues from the charts for settings and IIRC use Dot mode.
