Author Topic: Siglent SDS2000X Plus  (Read 938753 times)
0 Members and 19 Guests are viewing this topic.
Offline Bad_Driver
Re: Siglent SDS2000X Plus
« Reply #1325 on: June 06, 2020, 06:38:48 pm »
Ah! Thanks I got it!
Offline Elasia
« Reply #1326 on: June 06, 2020, 08:15:05 pm »
Nice Find :clap:
I am getting strong feelings of envy by not having a SDS2000X Plus - maybe time to join - TEA therapy - or simply get the damm device to enjoy the journey of discovery with you guy's   ;)
Do it.. it makes a good companion to that SSA/SVA ;)
I got a 3 foot long shelf both sit back on just above my main bench area
Online tautechTopic starter
Re: Bug confirmation request
« Reply #1327 on: June 06, 2020, 09:42:55 pm »
While testing my alternative digital probe adapter design i have found some quirks with Measure Statistics:
If all analog inputs are disabled the statistics of digital inputs are not updated, only the actual values are.
(Attachment Link)
Someone who can confirm?
I would struggle to expect any digital measurements to be correct when AC line triggering is selected.  :-//
Offline noreply
« Reply #1328 on: June 06, 2020, 10:06:59 pm »
Nice Find :clap:
Unfortunately I allready have a 'upgraded' SDS1104X-E (bought last year, well before the 2000X Plus series)
I also received a good suggestion (from tv - a possible 'TEA therapy' member??) that I should not hoard  :(
Maybe I should hold out until the 7000X series (if at all) hits the market??
BUT, the rational part of me , says, that if and when it does happen (the 7000X series) - its going to be in a different price league to the 2000X Plus series  :P
So your suggestion is very tempting - the excuse for me will be that I can use the 2000x Plus to 'calibrate' the SDS1104X-E  :P
With that in mind, for those of you in the UK is GBP 950 (EX VAT) a good price for a SDS2104X Plus ?
« Reply #1329 on: June 06, 2020, 10:28:32 pm »
1200 Euro is list price.
Offline jemangedeslolos
« Reply #1330 on: June 06, 2020, 10:31:54 pm »
7000X???   :scared:
Online Martin72
  • Testfield Technician
« Reply #1331 on: June 06, 2020, 10:36:34 pm »
Forget it, in a price manner.
5000X was beyond from hobbyists in that manner, 6000X more and what could then 7000X means...
(Kierkegaard)
Online DL2XY
« Reply #1332 on: June 06, 2020, 11:19:44 pm »
(Attachment Link)
The measurement is correct. Only statistics are not calculated/displayed.
This behavior is independent from trigger source, except if source is an analog channel (which must be active for trigger).
Why should trigger source compromise measurement of period or pulsewidth? Both are just counting sample clocks between edges in memory buffer.
Offline Elasia
« Reply #1333 on: June 07, 2020, 01:55:33 am »
Nice Find :clap:
I just sold my 1104X-E just the other day :P
Their 5k and up line all start at 3500usd min.. maybe when i got a bunch of cash with nothing to do but that is not today.. not worth it in my lab atm.. doubt that line goes lower less replaced and inventory sale
Offline Joao Carvalho
  • Country: pt
« Reply #1334 on: June 07, 2020, 04:42:29 pm »
Hello,
Long time reader but little posting,
Try the following with an AWG of 120 MHz and the scope.
Turn on Vpp measurements and in the aquire menu, set to 8 bits and for each frequency see both Vpp values for 8 bit’s and 10 bit’s, see the delta.
Manually go from frequencies from 10 MHz to 120 MHz in 10 MHz steps.
What do you see?
Do you see stability in 8 bit mode but an increasing in the delta of 8 bit to 10 bit mode?
Is this increase normal? Is it only explained by the 100MHz -3dB, but if so, it should only have an effect after 50 MHz? Right?
Last, a message for TV84, in Portuguese:
Amigo TV84, muito obrigado,
eu devo-lhe uma caixa de cervejas  :-)
Pensei que 580 MHz só em sonhos.
Thank you,
Best regards,
João Carvalho
Online DL2XY
« Reply #1335 on: June 07, 2020, 05:05:44 pm »
Hello,
What do you see?
Thank you,
Best regards,
João Carvalho
10 bit mode is only specified below 100Mhz.
See datasheet.
  • Country: pt
« Reply #1336 on: June 07, 2020, 06:04:13 pm »
Hello DL2XY, thank you for your reply,
I’m well aware of the -3db at 100 MHz for the 10 bit’s mode I was speaking about it in my post, but I had the perception that it only started to affect the measurement after half the bandwidth 50 MHz.
Knowing that the chip that makes the bandwidth limitation in hardware as a 100 MHz stop value, among others and that it is in the ~180MHz zone for the 100MHz stock scope.  I was hoping that the 10 bit would not be an exact digital filter of 100 MHz, and that it would not start making it’s effect on the accuracy of the measured Vpp of the signal before 50 Mhz, half the bandwidth.
Because of this mode (I know that there are other, like the 20 MHz and the 200 MHz), we have effetely two scopes inside one to compare.
So I took the following measurements of 1 Vpp at 8 bits and at 10 bits:
10MHz  8: 1.027V – 10: 1.0067V -> delta:  20.3mV
20MHz  8: 1.027V – 10: 1.000V -> delta:  27mV
30MHz 8: 1.031V – 10: 990mV -> delta:  41mV
40MHz 8: 1.033V – 10: 974mV -> delta:  59mV
50MHz 8: 1.030V – 10: 948mV -> delta:  82mV
60MHz 8: 1.031V – 10: 921mV -> delta:  110mV
70MHz 8: 1.032V – 10: 889mV -> delta:  143mV
80MHz 8: 1.028V – 10: 850mV -> delta:  178mV
90MHz 8: 1.029V – 10: 812mV -> delta:  217mV
100MHz 8: 1.025V – 10: 770mV -> delta: 255mV
110MHz 8: 1.032V – 10: 732mV -> delta:  300mV
120MHz 8: 1.030V – 10: 677mV  -> delta:  353mV
Best regards.
Online tv84
  • Country: pt
« Reply #1337 on: June 07, 2020, 06:32:37 pm »
João, obrigado.
Now that the forum has helped you, just continue posting to help others in the forum.
Online Martin72
« Reply #1338 on: June 07, 2020, 08:29:40 pm »
To have this famous christmas feeling (starting with the smallest parcel) I began with "improving" the FG-function and not the bandwith.
But this is the only one you have to use once before you can enter the code!!!!  |O
After hours I switched to other options which all worked and found that little bug! So never start with improving the FG-option without using it before!
Aha...
This could be the reason why I didn´t have the Problem while installing the keys - I´ve "played" with the FG before..
For newbies as me it is also worth mentioning that you have to do the bandwith improvement in steps from 100->200->350->500 and to avoid the others or
shortcuts (i.e. to try to go from 100->500 in one step)
My first step was turning 100Mhz to 350Mhz, then 500Mhz without a problem.
(Kierkegaard)
The following users thanked this post: Simon_RL
  • Country: pt
« Reply #1339 on: June 07, 2020, 08:39:21 pm »
TV84, I will.
Offline snoopy
    • Analog Precision
« Reply #1340 on: June 08, 2020, 07:09:21 am »
Has anyone checked to see if they can achieve the claimed 120K wfs/s acquisition rates on this scope ?? The measurements Dave made on the sds5000 scope was somewhat disappointing so I'm just wondering.
Also how fast is the serial decoding ?? Looks a bit sluggish from what I have seen.
Offline noreply
« Reply #1341 on: June 08, 2020, 10:53:51 am »
I’ve been thinking seriously  |O  about the purchase of a 2104X Plus and about to ‘push-the-button’ ...
For those of you also addicted to this device – so we can ALL benefit in a cost effective purchase – I propose a ‘bulk buy’ of perhaps 5 units.
This purchase is in the UK – so best suited for members who reside in the UK.
Delivery will be ‘next day’ (within the UK).
The ‘saving’ is likely to be 10% off the ‘street price’
If anyone is interested please PM
This is ‘open’ only for 7 days from today (date of post).
NOTE: I am not sure if posting a ‘bulk purchase’ request is against the forum rules OR there is a more appropriate section of the forums. I know there is a BUY / SELL section – but since this is a Siglent SDS2000X Plus thread – I thought it would get best traction here for those such as myself who have developed a strong (uncontrolled |O) desire to start ‘fiddling’ with this great bit of kit  :P
Moderator(s) please feel free to delete or move this post if appropriate.
Offline Elasia
« Reply #1342 on: June 08, 2020, 11:29:24 am »
You can normally get 5-7% off just by asking and saying your a forum member most places  :-+
So really it comes down to is an extra 40-60 bucks worth the hassle? Kinda ehh  :-//
Offline noreply
« Reply #1343 on: June 08, 2020, 11:39:29 am »
I hear what you say - but this is 'on top' of the forum discount  :-\
... anyway - just a though for those who are inerested  ;)
Offline notfaded1
« Reply #1344 on: June 09, 2020, 03:50:02 pm »
So can the $999 SDS2102X-Plus be fully upgraded with 4 channels and all features to 500MHz or is this where people are buying the 4 channel version instead of 2 thinking it'll warranty the 4 channel hardware at least again?  Also where can I get the best price on these from in the USA where they honor the EEVblog discount?
Thnx,
Bill
.ılılı..ılılı.
notfaded1
  • Country: pt
« Reply #1345 on: June 09, 2020, 04:09:04 pm »
I have test a little more and found that I can make with my AWG a burst of one cycle of a sinusoidal at frequencies up to 120 MHz. It has both channels synchronized so we can make phase shift measures of both channels, especially in the case of a 20 MHz channel limit (used here as an example) because it’s dependent on the channel and not globally to the scope, like the acquisition bit deep 8 bits and 10 bits. The small fixed AWG inter-channel was measured and accounted for, in the data appears as corr (correction) and was of 1.05 nS.
But all my measures of phase shift where made comparing Channel 1 with Full Bandwidth with Channel 2 with 20 MHz limited bandwidth.  I used math channels for both real channels with averaging and the phase measures between different bandlimit channel can’t be made with the Measurements menu, they had to be done by hand.
Note: I don’t know why the scope doesn’t permit inter bandwidth limit vs full bandwidth channel measurements.
The amplitude was also measured for the same channel with and without the bandlimit.
The connection between the scope and the AWG was a BNC 50 Ohms coaxial cable.
Please see the image and the excel file for the data.
There are considerable amplitude attenuations and considerable phase shifts as was expected.
The simple idea that I proposed is the correction of this effect and in this case I think that it could give a correction for the 20 MHz band limit of at least up to 40 MHz. In a normal 1 G sample scope the 20 MHz would be the 100 Mhz scope bandwith and the 40 Mhz would be the 500 Mhz Nyquiest limit. You have to use your imagination here :-D Like I said this can be made for any scope, for any bandwith, because it is made against the frequency response of the scope.
I use the 20 MHz band limit as an example and not as the final object, that is to correct for 0 Hz up to 1 GHz (950 MHz), but I don’t have a signal generator capable of hitting those high frequencies, I’m limit to what I have and that is a 40 Mhz Siglent AWG hacked to 120 MHz.
But I think that there is a way to make the phase frequency characterization of up to 1 GHz using a signal generator of a one single channel.
The ideia is that a low frequency sinusoidal signal ex: a 50 Mhz (10 %) for a 580 MHz scope are only really residually affected by a phase shift, and that high frequency signal is highly affected (phase shifted). So we have to find a way to compare the delta in time of the slow frequency wave top to the high frequency phase top, but we have to take out the part that is related to the fact the one wave is faster than the other, so we have to take out 1/4 period of the high freq wave times the frequency ratio between freq_ref_slow and freq_fast. And configure the channel of the fast signal wave to deskew for that delta. The result phase shift will be the real phase shift between the signals of different frequencies.  To better measure use coursers and invert the channel, comparing top Ref_A (slow) to Channel B (fast).
1 - First get the trigger to the oscilloscope from the trigger output port of the signal generator.
2 – Generate a 50 MHz tone with +13dBm (1.4 V, if you have more then better) in single cycle burst, do average and record it in REF_A.
3 – At all the frequencies in the freq range:
3.1 - Generate a sinusoidal of one cycle in a burst mode.
3.2 – Calculate the time delta for the frequency delta of the number of cycles for the relation between each signal A (REF_A low frequency and not affected by the scope frequency response) and Signal B (at 50 MHz, 100 MHz, 150, 200, …. 900, 950, 1 GHz )1/4  of Wave. Configure the scope channel skew to go backward in time only the number of cycles in the difference between frequencies ex: 50 Mhz to 100 Mhz or 1 GHz.
3.3 – Measure the time delta( then calculate the phase delta difference) difference between the two tops of the two sinusoids.
3.4 - Record the data.
Best regards,
João Carvalho
« Last Edit: June 09, 2020, 04:40:58 pm by Joao Carvalho »
  • Country: pt
« Reply #1346 on: June 09, 2020, 04:12:03 pm »
notfaded1 The 2 channel version doesn't have physically the other 2 channels of the 4 channel scope and has only one ADC of 2 G samples /sec so 580 MHz of bandwidth on 2 channels is out of question.
Best regards
João Carvalho
The following users thanked this post: notfaded1
Offline Elasia
« Reply #1347 on: June 09, 2020, 04:14:44 pm »
Thnx,
Bill
Saelig sells them with the blog discount
The difference between 2 and 4 channel is a hardware difference, they dont give you the 2nd adc pair
The lowest retail 4 channel is msrp 1400
Not sure what you mean by warranty but generally if you hack a unit of any brand consider it void
Offline notfaded1
« Reply #1348 on: June 09, 2020, 06:51:32 pm »
Ah I see now... some other vendors sold a recent scope like this where all 4 channels were there even in the two channel version ala Rigol MSO5072.  If you can reverse the hack and have a 4 channel scope then... so it looks you need the SDS2104X Plus then to really get started here with a 4 channel scope that can be "upgraded" fully.
Bill
.ılılı..ılılı.
notfaded1
Offline TK
« Reply #1349 on: June 09, 2020, 07:28:00 pm »
Thnx,
Bill
The 2-channel model only has BNCs for CH1 and CH2 at the front
