Ok I see, much of that can be done with the 2kX Plus also when connected via LAN to the webrowser and even the little 7" display X-E's. Reimporting is more difficult and can really only be Reference files which of course you can still measure etc.
So in practice we would maybe move from the scope controls to the PC and work the scope with a mouse just like the Pico I presume.
Yes, you can do some of the things remotely, I use this with my Keysight (it also has VNC remote control, and web control page that makes thing easier) but it is very limited compared to scope App being real windows app running on your real PC. For instance, I'm confused why scopes with Ethernet interfaces and Linux on it don't allow me to map network drives (NFS or Samba, I don't care), so I can stop using stupid USB keys for captures, masks or captures. For instance, save on mask failure... Some GW Instek and Tek scopes can do it, but none of embeded ones can.. Only windows based ones..
I'm looking at you Keysight too, really on 3000T/4000/6000 series that should be a built in feature. It would be much more useful than fully featured TCP/IP Print server that is so 80-is.
Nobody prints to printer directly..
Also, since it is software decode, you can capture something, save it, open it next day and then play with math, decodes .... And then make documentation form that. And a week after, you remember something, open it again, and grab another view and add it to documentation..
This saving/restoring of the whole system state (i.e. settings and full data) is a feature that LeCroy scopes had for at least a decade or so and that is unfortunately absent from any other (standalone) brand (AFAIK). It's a bit of a letdown that Siglent doesn't seem to intend to offer something like that. Same is true for other unique LeCroy things like WaveScan and LabView, but there I could at least imagine that directly copying the idea wouldn't make LeCroy happy. Saving/restoring of the state+data is such a basic concept though that it's hard to imagine this could be protected anyhow.
Agree. Just to mention it, higher end R&S scopes have it too, together with fancy previews and such.
I bought Pico because it is cheapest way to get many high end usability and analytical features (DeepMeasure, unlimited decodes, unlimited aribitrary math etc etc)...
Mind you, there are many things about it that I don't like, but it is very powerfull tool, if you take time to learn how to use it.
