Author Topic: Siglent SDS2000X Plus  (Read 938884 times)
movie and 10 Guests are viewing this topic.
Offline tautechTopic starter
Re: Siglent SDS2000X Plus
« Reply #1175 on: May 19, 2020, 05:37:29 am »
Good news, can´t await to test it.
Test it real good as the release notes are missing stuff I've reported weeks and weeks ago.  :horse:
Online Martin72
  • Testfield Technician
« Reply #1176 on: May 19, 2020, 07:32:38 pm »
A few minutes ago I´ve done the upgrade.
Hide channel - Works... :-+
Box Information for math - Works.. :-+
Not so nice, part 1:
In the channelbox before upgrade "DC1M", "DC50", "AC1M" "AC50" were displayed, when you took the settings to this.
Now the "C" get lost, it will displaying "D1M" instead of "DC1M" and so on.
I think it's because now there´s an H for Hidden displaying when you activate this function - Maybe it could be corrected, but it´s not really worrying me.
Not so nice, part two:
For hiding the channel, you must go into the channel menu, scrolling down to the last - From lecroy models I´m used to use the channel button for this ( pressing once, channel hides).
Edit: After doing the fw upgrade, I still got all options and full bandwith, so no worries.
« Last Edit: May 19, 2020, 08:08:05 pm by Martin72 »
(Kierkegaard)
Offline thinkfat
    • Matthias' Hackerstübchen
« Reply #1177 on: May 20, 2020, 08:41:13 am »
I did the upgrade yesterday as well. All options preserved. Being able to hide the analog channel is nice.
Offline Elasia
« Reply #1178 on: May 20, 2020, 12:42:36 pm »
I did mine as well, worked fine
Offline TK
« Reply #1179 on: May 23, 2020, 03:35:30 pm »
Homemade SPL2016 equivalent probe.  Tested 5V TTL logic, 3.3V, negative CAN signal as generated by Keysight 1000X scope training signal
PM me if you are interested in buying one
« Last Edit: May 23, 2020, 03:40:00 pm by TK »
The following users thanked this post: mnementh, oz2cpu, Simon_RL
Offline Frex
« Reply #1180 on: May 23, 2020, 03:49:29 pm »
Hello TK,
It's interesting, as I don't have bought the Logic probe yet that is really overpriced.
So, does your adapter include active/passive parts ?
Have you tested the upper  frequency limit where it still work ?
Picture seem to show that it's only an adapter between the PCI-E connector
and an double row 2.54mm header connector, it is that ?
Regards.
Frex
Offline TK
« Reply #1181 on: May 23, 2020, 03:54:50 pm »
Hello TK,
Regards.
Frex
The adapter is only a PCB.  The passive matching components are in the original HP / Agilent POD I am using, paired with the original HP woven ribbon cable that was used by HP in their logic analyzer product line.  I am selling the whole cable set, fully assembled as shown in one of the pictures (PCB adapter, original HP woven cable, original HP/Agilent data POD).
I tested 45MHz SPI clock signal.  I also generated a 100MHz square signal and the signal is not 50% duty square signal, as the sample rate for digital input is 500MSa/s, I estimate the reliable capture speed is around 60MHz - 80MHz.
It works with serial decoding.  It also works with negative threshold... I tested a negative CAN signal generated by my KS scope training signal and set the threshold to around -1.5V on the Siglent and it captures and decodes perfectly.
It lacks the casing, so I made a horizontal piece made with PCB and that holds the vertical board in place, but the PCB assembly does not latch to the Siglent scope case.
« Last Edit: May 23, 2020, 03:57:01 pm by TK »
Offline Frex
« Reply #1182 on: May 23, 2020, 04:45:42 pm »
Ok, thanks for the explanation. That seems fine.
What would be the price for this complete kit ?
It is a used or new HP/Agilent digital probe pod ?
Regards
Frex
Offline TK
« Reply #1183 on: May 23, 2020, 04:55:24 pm »
Regards
Frex
They are vintage used genuine HP/Agilent parts.  In the picture I am showing a POD that is not in a very good shape, for my own use. The ones I sell are in better condition.  I made minor changes to the PCB and I am waiting for the new ones to arrive... I expect to ship them end of next week or the week after.  I've been selling a similar cable (different adapter) assembly for Agilent 54622D and Agilent / Keysight MSOX (2000X-4000X) users for many many years.  I think the price is reasonable, send me a PM.
Offline Elasia
« Reply #1184 on: May 23, 2020, 05:23:33 pm »
Regards
Frex
Way cheaper than the siglent probes, 350 is woof... i did get the boobie prize at least and the mini grabbers it came with are high quality
Offline jemangedeslolos
« Reply #1185 on: May 26, 2020, 12:45:17 pm »
Hello :)
Sorry if the question has already been asked, but the most interesting thing in this video is the keyboard :
Do you know the part reference ?
It would do very nice on my desk  ;D
Thank you !
Offline 0xdeadbeef
« Reply #1186 on: May 26, 2020, 01:33:33 pm »
Could be a Ducky.
Offline Elasia
« Reply #1187 on: May 26, 2020, 01:34:41 pm »
Hello :)
Thank you !
It's just a compact keyboard with some replacement color keys
https://mechanicalkeyboards.com/shop/index.php?l=product_list&c=28
Offline Elasia
« Reply #1188 on: May 26, 2020, 01:37:57 pm »
Could be a Ducky.
Doubt it.. whoever probly just grabbed one off a rack and a handful of color keys if its anywhere near shenzhen; mass produced and all look the same
Offline Svrbinek
« Reply #1189 on: May 26, 2020, 03:51:12 pm »
Hi. After the upgrade, the display in the web interface on the PC no longer works. is just a white window. Can you confirm that? Is it possible to downgrade?
Offline Elasia
« Reply #1190 on: May 26, 2020, 06:33:56 pm »
mine works, is it still on the same ip address?
Offline Svrbinek
« Reply #1191 on: May 26, 2020, 07:37:28 pm »
Yes, it's at the same address. I get to the whole web server, just the place of the window where the wave should be visible is a white window.
« Reply #1192 on: May 26, 2020, 08:21:43 pm »
What PC OS and browser are you using ?
Maybe install the new FW again for a double check.
Should be no problem, here's the release FW:
https://www.siglenteu.com/download/8989/
Offline thinkfat
« Reply #1193 on: May 26, 2020, 10:48:22 pm »
Still works here since the update.
Offline Svrbinek
« Reply #1194 on: May 27, 2020, 05:29:49 pm »
I updated via the web interface. Now I have tried it again via the web interface and it already works. To be sure, I recorded it on flash memory if it didn't work again. Probably the first update was not 100% successful, but otherwise everything seemed to work in the Oscilloscope. So thanks for the advice, the second attempt at update fixed it.
Online Martin72
« Reply #1195 on: May 30, 2020, 11:04:35 pm »
The siglent deskew fixture makes me so curious, that now I´ve ordered one:
DF2001A
(Kierkegaard)
Offline Elasia
« Reply #1196 on: May 31, 2020, 02:50:08 am »
DF2001A
That thing is on my short list, let me know what you think of it.. when is it coming in?
Online Martin72
« Reply #1197 on: May 31, 2020, 10:24:36 am »
Yesterday purchased, I think in the forthcoming week.
(Kierkegaard)
Online 2N3055
  • Country: hr
« Reply #1198 on: May 31, 2020, 01:27:45 pm »
I'm hoping for nice hires photo of the board.. :) 250€ is too much for my blood... It's a oscillator, mosfet, two resistors, and a pcb trace.
I was thinking also about a version with breakable loop for wired current sensors...
Offline Elasia
« Reply #1199 on: May 31, 2020, 02:20:58 pm »
Great minds think alike ;)
https://www.siglenteu.com/wp-content/uploads/2017/11/DF2001A.jpg
Not the best photo but will get most of the board, whats really needed is a bom and its pretty evident its just a 2 layer board.. so just a front and back photo and then some with light going through to confirm
