Hello friends of the Siglent SDS2000X Plus.
I have just downloaded and tried out the SDS200X Plus manual from the Siglent homepage www.siglenteu.com. It is called "SDS2000X-Plus_UserManual_UM0102XP-E01A.pdf". Everything works without errors. Also another user has no problems, so the error must be yours.
Therefore always be careful with error messages, thank you.
Addendum.
I also tried the built-in manual (Help), that works fine too. I have to say, I have a SDS2354X Plus which is not hacked. Hacking is indecent.
Addendum.
If you have downloaded the manual from the homepage www.siglent.eu there are a few small errors. But www.siglent.eu is not Siglent Europe, it's just a dealer.
Siglent Europa has the homepage www. Siglenteu.com
There are two version of PDF of the same latest version manual out on internet.
One that I downloaded from
siglenteu.com , the official Siglent EU site, ver "UM0102XP-E01A " is called "SDS2000X-Plus_UserManual_UM0102XP-E01A.pdf" and is 25,7 MB (27.022.244 bytes) in size , and gives error when opening.
Error is : "- The object was not described in the current, or previous, chunks, but a description was found in the next chunks (valid for linearized files)"
Same manual "UM0102XP-E01A", "SDS2000X Plus_UserManual_UM0102XP-E01A.pdf", from
siglent.com (official US Siglent site) is 34,9 MB (36.681.527 bytes) in size and gives no error when opening.
But both versions have problem with searching in PDF viewer PDF-XChange Editor. For instance if you search for word "peak" (like peak detect) it doesn't find it. That same search works just fine in SDS5000X PDF Manual. When trying to open it in Adobe reader XI it crashes the reader completely when you start search.
So no it's not fine..
