Author Topic: Siglent SDS2000X Plus  (Read 938602 times)
Bad_Driver and 17 Guests are viewing this topic.
Offline Svrbinek
Re: Siglent SDS2000X Plus
« Reply #625 on: March 05, 2020, 08:01:24 pm »
I don't know if any mouse and keyboard can be connected, but if so, I'll try and use it. I thought they delivered the keyboard and mouse automatically, but they didn't.
Online Martin72
  • Testfield Technician
« Reply #626 on: March 05, 2020, 08:09:45 pm »
You can buy them from the money you saved by the discount... ;)
(Kierkegaard)
Online tautechTopic starter
« Reply #627 on: March 05, 2020, 08:14:03 pm »
Just using a mouse can help a lot however I'm not sure how useful they are with gestures like pinch to zoom....I really need to try it.  :-[
A keyboard will be faster for naming screenshots and labeling traces etc than the 'on screen' virtual keyboard however it depends on how often you'll need to use these features.
Offline Svrbinek
« Reply #628 on: March 05, 2020, 08:22:29 pm »
I guess I would rather solve it via laptop and web server. The one I have tried affects just fine. So I have a keyboard and a mouse :-)
« Reply #629 on: March 05, 2020, 09:03:13 pm »
Got your PM.
For now just get to know your new 2kX Plus as you have a big task just to learn all its capabilities and in time there will be more info about what you ask available online.  ;)
I still have to get mine and have a play with it...this weekend I hope !
Offline Svrbinek
« Reply #630 on: March 05, 2020, 09:03:41 pm »
So I have come across the first thing I do not know how to set or it does not work :-( I need to show a slow progress of switching PIR sensor and I have a base of 1s, but I need to render the signal in real time and not after a few seconds. I tried to reduce the memory and it did not help anyway, Agilent renders it slowly online.
Offline Svrbinek
« Reply #631 on: March 05, 2020, 09:10:27 pm »
Thanks a lot for the answer. I'm glad you have this information and I'm looking forward to it. I do not want to waste AWG testing for the time being, when there is only 30 times the possibility to run.
Next, I'm posting a video of the problem I described above. Can it be viewed as Agilent?
https://youtu.be/Ab7wBVOrEAw
« Reply #632 on: March 05, 2020, 09:10:48 pm »
For slow timebase settings you have 2 options, Auto Roll mode activates at settings slower than 50ms/div and dedicated Roll mode accessible with the front panel Roll button.
Use plenty of memory and let the scope decide the depth to use. I always use the max memory setting.
The following users thanked this post: Svrbinek
Offline Svrbinek
« Reply #633 on: March 05, 2020, 09:15:10 pm »
Perfect :-) Works exactly as I needed :-) Actually better than Agilent. I was worried that Siglent was lagging behind :-)
Online Martin72
« Reply #634 on: March 05, 2020, 09:29:45 pm »
True, but...interesting….I like more to use the touchscreen - Which is somekind of funny for someone who didn´t like tablets….
But it offers a nice test also, I´ll check it on the weekend.
The little response lag between touching an element and activate it - Will it be gone by using the mouse…
Must test it.
(Kierkegaard)
« Reply #635 on: March 05, 2020, 10:23:37 pm »
Must test it.
Each to their own however bench layout and space requirements often dictate how/where you might use and place a scope.
SDS5054X used exclusively with a mouse and keyboard:
Offline Svrbinek
« Reply #636 on: March 05, 2020, 10:53:03 pm »
So tidy just got twice a year:-D Very beautiful
« Reply #637 on: March 05, 2020, 11:34:14 pm »
That's not my bench by any chance !  :palm:
It's a customers bench when he was part way through setting it up for the new job he had. Nice his new boss let him buy some nice tools.   :)
Offline maginnovision
« Reply #638 on: March 05, 2020, 11:51:36 pm »
 :-DD Was he waiting to set the nice ones up? Just kidding.
« Reply #639 on: March 06, 2020, 12:20:12 am »
Yeah not impressed with the soldering gear he selected when it might've been Metcal or Pace.
Just kidding.
I'm not !  :P
« Reply #640 on: March 06, 2020, 12:22:17 am »
Yea, an 888 definitely looks out of place. The Hakko hot air units also aren't anything to write home about. The fume extractor is ok though.
« Last Edit: March 06, 2020, 12:23:56 am by maginnovision »
Online Martin72
« Reply #641 on: March 08, 2020, 08:26:33 pm »
To transport my siglent safety to work ( train, bus) and to keep it away from dust, I´ve just bought this here:
https://www.amazon.de/dp/B00H25JMPK/ref=pe_3044161_185740101_TE_item
Hope, I´ve choosed the right size - I hate sending things back... ;)
(Kierkegaard)
Offline Pinkus
« Reply #642 on: March 09, 2020, 08:36:00 am »
Probably too small as you also have to store power cable, probes etc. and you want to have enough foam protection around the scope. I guess I would've bought the type 5000 instead.
Offline jmag999
« Reply #643 on: March 09, 2020, 12:48:23 pm »
Does anyone know if this scope is capable of recording a video of the screen for some period of time (to a usb stick, for example)?
Offline TK
« Reply #644 on: March 09, 2020, 01:05:27 pm »
The only scope I know that can record video is the micsig.
The following users thanked this post: nctnico
« Reply #645 on: March 09, 2020, 04:18:40 pm »
Yea, any scope with a web interface you'll be able to record a video even if it's not an explicit feature.
Online Martin72
« Reply #646 on: March 09, 2020, 05:47:02 pm »
Maybe someone has an even simpler suggestion.
Videocam.  ;)
Hm-hm....makes me nervous, case should arrive in the next hours.
(Kierkegaard)
« Reply #647 on: March 09, 2020, 07:05:13 pm »
Real actual use case ?
There might be more than one way of skinning this cat.  ;)
Online Martin72
« Reply #648 on: March 09, 2020, 08:38:59 pm »
Yepp, it´s too small - The siglent fits but without any space...Return to sender and buying the next greater version.
(Kierkegaard)
« Reply #649 on: March 10, 2020, 01:23:32 am »
New arrival but too busy for a bit to even unbox it.  ::)
