Author Topic: Siglent SDS2000X Plus  (Read 938626 times)
0 Members and 19 Guests are viewing this topic.
Online Martin72
  • Testfield Technician
Re: Siglent SDS2000X Plus
« Reply #475 on: February 16, 2020, 11:06:28 am »
Martin, with the button Instrument Control you switch the browser to the SDS, see Scrennshot from tautech.
I know this already, otherwise, I wouldn't have been able to take a picture from it.  ;)
(Kierkegaard)
Online Martin72
« Reply #476 on: February 16, 2020, 11:18:27 am »
What are you doing wrong that the selection is still visible on the left?
Don´t know, but I´ve found a fullscreen button on the lower right of the screen.
And forget what I said about the function button, the scope is fully controllable - I was irritating that the mouse-pointer doesn´t change it´s outfit when you go to a active field.
So you can control the scope on pc as if you do it directly with mouse on scope.
(Kierkegaard)
Online Martin72
« Reply #477 on: February 16, 2020, 11:23:53 am »
(…)then I press Intrument Control, then comes the SDS screen and the selection on the left side (Intrument Control etc.) is gone.
I do the same and nothing is gone.  ;)
Maybe a behaviour of my browser (Edge).
(Kierkegaard)
Offline tautechTopic starter
« Reply #478 on: February 16, 2020, 11:42:14 am »
Maybe. Can you try another browser to check if it's the same ?
In Chrome only the display is visible and you can scale it to fit your remote display with Ctrl/mousewheel or Ctrl/Up/Down arrows.
To return to the webrowser panel window you just hit Esc.
Online Martin72
« Reply #479 on: February 16, 2020, 11:50:07 am »
I´ll try it later in the afternoon.
(Kierkegaard)
Online Martin72
« Reply #480 on: February 16, 2020, 04:39:45 pm »
Quote from: tautech
Just try it with chrome from my Smartphone, then it looks like yours.
So it´s dependable from which browser you use.
(Kierkegaard)
« Reply #481 on: February 16, 2020, 07:28:44 pm »
OK, but the Rigol MSO5000 has a webserver, too, right?
Ok so it does, I just looked it up.
So it's not really an advantage for the Siglent to not have an HDMI output ;)
Right, however with a webserver there is the workaround to port the display to another monitor.
However the omission of 50 ohm inputs and probe sense is more of an oversight in an 8 GSa/s DSO.
The SCSI style MSO connector is a bit 'yesterday' too.
ymmv  ;)
Online Martin72
« Reply #482 on: February 16, 2020, 08:35:09 pm »
This is the result when you want to bring your new technique as cheap as it can get on the market.
With proper display, 50ohm inputs, probe sensing etc., you´re at the pricerange of a rigol 7000 which already exists.
If 8GSa/s is not important, then…..Bingo.  ;)
(Kierkegaard)
« Reply #483 on: February 17, 2020, 08:42:45 am »
Managed to nab just one unit from the factory today and I'll have it in a week or so.  :phew:
Online Martin72
« Reply #484 on: February 17, 2020, 09:18:14 pm »
Batronix and Welectron here doesn´t have the 2104 on stock anymore - Look like it´s selling well.
(Kierkegaard)
Offline TK
« Reply #485 on: February 17, 2020, 10:48:03 pm »
In my opinion siglent never sent many units to the distributors and they got caught by the virus shutdown, I don't think they sold many units, actually yours seem to be the only unit out there
Online Martin72
« Reply #486 on: February 17, 2020, 10:57:20 pm »
It seems so.
But the "higher" models (200Mhz and more) are avaible.
(Kierkegaard)
« Reply #487 on: February 18, 2020, 01:27:26 am »
Nope, initial production runs were fully sold to distributors prior or very shortly after release. When I went to get some weeks ago they just weren't available.
There's now at least 2 other members here with 2kX Plus models so 3 members at least with them.
It seems so.
As above however I could only get just one single 2104X Plus yesterday and I wouldn't be surprised if it was robbed from another distributors order that's waiting for a production run of something else.
I wanted a 2354X Plus so to have the top model as a demo unit but the 100 MHz version will have to do for now.  :(
Offline DL2XY
Tek Mode
« Reply #488 on: February 18, 2020, 09:12:56 pm »
Has someone an idea what this "Tek Mode" stand for?
930698-0
I have found nothing about in the documentation  :-//
« Last Edit: February 18, 2020, 09:16:32 pm by DL2XY »
Online Martin72
« Reply #489 on: February 18, 2020, 09:51:23 pm »
Well, this would be a less problem to change... :-X ;)
LOL, didn´t recognize it so far…
Maybe it´s an "artifact" like the also mentioned debug mode in the menu.
« Last Edit: February 18, 2020, 09:53:30 pm by Martin72 »
(Kierkegaard)
Offline Pinkus
Re: Tek Mode
« Reply #490 on: February 18, 2020, 11:27:41 pm »
(Attachment Link)
It slows down the user interface reaction and display output to 25% speed? gg
The following users thanked this post: pizzigri
« Reply #491 on: February 19, 2020, 06:25:46 am »
Certainly, now there is a script available.  ;)
Dunno what the Tek mode is all about but I'll ask the product manager when I get mine.  :-//
Debug mode is in the SDS5000X too and it's a tool for engineers and beta testers to pull reports out of the scopes OS and the password for it is ........ :-X  ;)
Had a look around in there and it's not a place to change anything unless you really know what you are doing.  :scared:
Offline thinkfat
    • Matthias' Hackerstübchen
« Reply #492 on: February 19, 2020, 09:05:53 am »
... the password for it is ........ :-X  ;)
That reads as "hunter2" over here... :wtf:
« Reply #493 on: February 19, 2020, 09:13:00 am »
Nope, more characters.  :-X
« Last Edit: February 19, 2020, 09:15:57 am by tautech »
Offline thinkfat
« Reply #494 on: February 19, 2020, 09:17:38 am »
Don't worry, kid, I'm sure someone else will get it ;)
« Reply #495 on: February 19, 2020, 09:24:54 am »
It's known to a few outside Siglent and that's how I found what it was but seriously a peek in there is all I needed to see then promptly logged out !  :scared:
I paid a lot for my SDS5104X SDS5054X an I don't wanna break it ! It's my very special baby !  :)
Offline jemangedeslolos
« Reply #496 on: February 19, 2020, 10:29:57 am »
Hello Martin72,
A little question for you regarding serial decoding.
Would you say it is better or worse on the SDS2000+ compared to the MSO5000 ?
The serial decoding is much better on my MSO5000 than on my previous SDS2000X ( non plus ).
So I wonder how this new model behaves compared to the MSO5000 ( triggering on char for example and your general feeling regarding this )
Thank you  ;)
Offline Svrbinek
« Reply #497 on: February 19, 2020, 04:45:49 pm »
Hi, would anyone want to make a video review on this oscilloscope? There is nothing on the internet yet and I am eagerly waiting for when it will be :-) I really think about it but there is nowhere.
Offline Electro Fan
« Reply #498 on: February 19, 2020, 05:10:02 pm »
+1
Maybe Dave could put a Rigol 5000 vs a Siglent X Plus comparison review into the video queue :)
Online Frex
« Reply #499 on: February 19, 2020, 05:49:30 pm »
I will love too a Dave's video review about the Siglent SDS2000X Plus,
 there is not really real use info about it other than commercial promotion.
Comparing with MSO5000 is also a good idea, almost same price tag scope.
Frex
