Test it again and lowered the timebase to 100ms - It decodes 15000 packages and this is the limit, at 200 or 500ms the amount is fixed to 15000.
Hi,Bigger screen (10" instead 7"), zone trigger, autosense probe inputs, 50ohm Inputs, formular editor (math), "real" built in awg, touchscreen, have a look at the two specsheets:
Maybe I get it wrong, but I took a squarewave ( I borrowed my stb-3 today) of 1Mhz, zoom in it measures the edges, zoom out, it measure it too.
But it couldn´t measure more than 200000 edges.
Yes and it indicates that.
At least it's measuring something but this "saturation" is somewhat alarming. I wonder if other measurements like DC and the average etc. calculated from them are also only performed for a part of the measured data.Besides: does this counter count both edges or did you configure it that way? With only one edge counted, I would have expected 100k edges with 10ms/div and 1MHz square wave.
Quote from: 0xdeadbeef on March 02, 2020, 10:55:35 pmAt least it's measuring something but this "saturation" is somewhat alarming. I wonder if other measurements like DC and the average etc. calculated from them are also only performed for a part of the measured data.Besides: does this counter count both edges or did you configure it that way? With only one edge counted, I would have expected 100k edges with 10ms/div and 1MHz square wave.And what is the practical use of such a measurement ?
Quote from: tautech on March 02, 2020, 10:59:39 pmQuote from: 0xdeadbeef on March 02, 2020, 10:55:35 pmAt least it's measuring something but this "saturation" is somewhat alarming. I wonder if other measurements like DC and the average etc. calculated from them are also only performed for a part of the measured data.Besides: does this counter count both edges or did you configure it that way? With only one edge counted, I would have expected 100k edges with 10ms/div and 1MHz square wave.And what is the practical use of such a measurement ? Think about tracking math where you can see a demodulated PWM waveform. Or as I wrote before: numerical analysis of a long train of pulses to know the min/max and average. A useful purpose is to measure the time a microcontroller is spending inside an interrupt routine measured over a longer period of time.
In fact, I only want to measure what´s actually on the screen.
Statistics and Histograms are the more appropriate tools for this.
Quote from: nctnico on March 02, 2020, 11:13:56 pmQuote from: tautech on March 02, 2020, 10:59:39 pmQuote from: 0xdeadbeef on March 02, 2020, 10:55:35 pmAt least it's measuring something but this "saturation" is somewhat alarming. I wonder if other measurements like DC and the average etc. calculated from them are also only performed for a part of the measured data.Besides: does this counter count both edges or did you configure it that way? With only one edge counted, I would have expected 100k edges with 10ms/div and 1MHz square wave.And what is the practical use of such a measurement ? Think about tracking math where you can see a demodulated PWM waveform. Or as I wrote before: numerical analysis of a long train of pulses to know the min/max and average. A useful purpose is to measure the time a microcontroller is spending inside an interrupt routine measured over a longer period of time.Statistics and Histograms are the more appropriate tools for this.
Quote from: tautech on March 02, 2020, 11:18:19 pmStatistics and Histograms are the more appropriate tools for this.But those are also devaluated by limiting the measurements to a certain amount. Is this threshold (200k) at least documented somewhere?
The pot is full with a delicious soup, everyone is satisfied.Only one is looking for the hair in the soup that doesn't exist. The one has to buy the soup he thinks there is no hair in the soup, even if it costs 10 to 20 times more than the tasty, cheap soup the others taste.
