Author Topic: Siglent SDS2000X Plus  (Read 914204 times)
0 Members and 15 Guests are viewing this topic.
Offline gralco
Re: Siglent SDS2000X Plus
« Reply #3200 on: February 18, 2022, 05:51:56 am »
I just added a pull request in Sigrok Pulseview to support the SDS2000X Plus series, feel free to test it and give feedback: https://github.com/sigrokproject/libsigrok/pull/176
The following users thanked this post: dreamcat4, Markus2801A, doppelgrau, djnebs, Dracarris
Offline tv84
  • Country: pt
« Reply #3201 on: February 19, 2022, 10:16:28 am »
I've been away from these fights...
Has anyone tried the "EJ" and "SENT" options on the SDS2000X+?
Offline blurpy
  • Country: no
« Reply #3202 on: February 19, 2022, 10:37:23 am »
What's the "EJ"? option?
Edit: oh, eye diagram that is available for SDS6k: https://siglentna.com/product/eye-jitter-analysis-sds6000a/
« Last Edit: February 19, 2022, 10:39:18 am by blurpy »
Offline tv84
  • Country: pt
« Reply #3203 on: February 19, 2022, 10:50:55 am »
Software has it like this:
EJ    - SDS-5000X-EJ       - SDS_2000XP_EJ      - SDS6000Pro-EJ
Offline blurpy
  • Country: no
« Reply #3204 on: February 19, 2022, 06:56:59 pm »
Also looks like a new file options_ej_times.txt showed up in the 1.3.9R4 firmware:
$ ls -la options_*
------xr-x 1 user users 2 april 10  2021 options_1553b_times.txt
---------x 1 user users 2 april 10  2021 options_awg_times.txt
------x--x 1 user users 2 april 10  2021 options_canfd_times.txt
-rw------- 1 user users 2 sep.  11 13:14 options_ej_times.txt
------x--x 1 user users 2 april 10  2021 options_flx_times.txt
------xr-x 1 user users 2 april 10  2021 options_i2s_times.txt
---x------ 1 user users 2 april 10  2021 options_manc_times.txt
-------r-x 1 user users 2 april 10  2021 options_mso_times.txt
---------x 1 user users 2 april 10  2021 options_pa_times.txt
---x------ 1 user users 2 april 10  2021 options_sent_times.txt
-------r-x 1 user users 2 april 10  2021 options_wifi_times.txt
Offline tubularnut
« Reply #3205 on: February 19, 2022, 07:22:37 pm »
I already have SENT enabled, but never had reason to use it.
(I believe) I've generated the code for EJ using the Python script, but there is no option to install it (1.3.9R6)
Offline tv84
  • Country: pt
« Reply #3206 on: February 19, 2022, 10:04:35 pm »
Use the SCPI command:
LCISL optioncode,hexkey
Offline tubularnut
« Reply #3207 on: February 20, 2022, 06:42:12 am »
No joy.
Tried the format below, and rebooted afterwards. No extra option shown enabled, and nothing extra menu under Analysis.
LCISL EJ,wwww-xxxx-yyyy-zzzz
Also tried variations of case, spacing and no dashes.
« Last Edit: February 20, 2022, 10:15:43 am by tubularnut »
Offline tv84
  • Country: pt
« Reply #3208 on: February 20, 2022, 09:38:25 am »
Why the dashes? It should be no dashes but others may confirm.
Offline tubularnut
« Reply #3209 on: February 20, 2022, 10:05:37 am »
The script produces the codes with dashes.
I can’t recall when I did the others originally, but I think I typed them onto the screen, so dashes are not used anyway, but I have tried without dashes via command too.
« Last Edit: February 20, 2022, 10:15:08 am by tubularnut »
The following users thanked this post: tv84
Offline tv84
  • Country: pt
« Reply #3210 on: February 20, 2022, 10:56:32 am »
And what is your FW version, at this moment?
Offline tubularnut
« Reply #3211 on: February 20, 2022, 10:57:24 am »
1.3.9R6
Offline tv84
  • Country: pt
« Reply #3212 on: February 20, 2022, 10:58:44 am »
1.3.9R6
In your NSP_system_info.xml is there any reference to a "Dynamic Key"?
Offline tubularnut
« Reply #3213 on: February 20, 2022, 11:06:14 am »
I'll need to setup a drive for the telnet access, I've never had need to go in before.
 I assume the method in https://www.eevblog.com/forum/testgear/siglent-sds2000x-plus-coming/msg3006340/?topicseen#msg3006340 still works?
Offline tv84
  • Country: pt
« Reply #3214 on: February 20, 2022, 11:28:19 am »
More or less. Inside the .sh use this line:
/usr/sbin/telnetd -l /bin/sh
Offline Martin72
  • Testfield Technician
« Reply #3215 on: February 20, 2022, 11:38:57 am »
Because there is no eyediagram/jitter analyzis option for the 2000XP in real, this isn´t a hidden easteregg feature..
I think, it´s only "there" because all the three scopetypes are using more or less the same software.
A few months before, we got the same problem on a lecroy if I remember it right.
Installing all "theoretical possible" licenses but won´t work correctly.
I think it was on a WS3000 scope.
(Kierkegaard)
Offline tubularnut
« Reply #3216 on: February 20, 2022, 11:39:40 am »
That worked a lot better :-)
/usr/bin/siglent/firmdata0 # cat NSP_system_info.xml
<?xml version="1.0" encoding="UTF-8"?>
<nsp_system_info_root>
  <device>
    <system_information>
      <serial_number>
        <chip>XXXXXXXXXXXXXXXXX</chip> (S/N removed)
      </serial_number>
    </system_information>
  </device>
<Device><Mac>74:5b:c5:20:7b:e2</Mac></Device></nsp_system_info_root>
Offline tubularnut
« Reply #3217 on: February 20, 2022, 11:41:45 am »
Makes sense :-(
Offline tv84
  • Country: pt
« Reply #3218 on: February 20, 2022, 11:57:20 am »
Martin, understand but this isn't the same "only there".
There is the explicit license designation "SDS_2000XP_EJ" in there and this only happens when there is a real reason. It's not only "EJ".
Of course, can be in beta, may need a flag to activate, not yet releasable, etc. But it's explicitly inside.
It's not like a "1000M" reference that we are trying to make it work in a SDS2k+.
Offline Martin72
« Reply #3219 on: February 20, 2022, 12:02:06 pm »
Hm, interesting... :D
(Kierkegaard)
Offline blurpy
  • Country: no
« Reply #3220 on: February 20, 2022, 12:35:12 pm »
The eye diagram feature seems to be guarded by a lot of checks everywhere for product type, so enabling the license might not have any effect.
Not sure if this is just because they want us to buy the most expensive model, or if this feature requires some hardware or fpga logic not in the SDS2000X+. Could also be that it's unfinished like tv84 says.
Offline tubularnut
« Reply #3221 on: February 20, 2022, 01:07:40 pm »
Well, trying the key did something, though permissions are different to others:
---x------    1 root     root            20 Nov 15  2020 options_canfd_cfg.bin
---x------    1 root     root            20 Nov 15  2020 options_canfd_license.txt
-rw-------    1 root     root            20 Feb 20 11:59 options_ej_cfg.bin
-rw-------    1 root     root            20 Feb 20 11:59 options_ej_license.txt
---x------    1 root     root            20 Nov 15  2020 options_flx_cfg.bin
---x------    1 root     root            20 Nov 15  2020 options_flx_license.txt
---x------    1 root     root            20 Nov 15  2020 options_i2s_cfg.bin
« Last Edit: February 20, 2022, 01:10:06 pm by tubularnut »
Offline tv84
  • Country: pt
« Reply #3222 on: February 20, 2022, 02:01:58 pm »
No problem with the permissions. Well, that somewhat confirms that my suspicion was right. Let's all try to better understand the environment...
Offline 2N3055
  • Country: hr
« Reply #3223 on: February 20, 2022, 02:42:12 pm »
Offline Emo
« Reply #3224 on: February 20, 2022, 03:25:00 pm »
OK,I can confirm the SCPI command+key is accepted on SDS5k. No additional menus appear. However at the risk of misleading you I noticed the trigger setting on "pattern" after the reboot. Which I didn't use before.
FW; 095R3
