But there's a reason why LeCroy has been and still is the number one when it comes to analysis scopes, and there is a solid demand for scopes which go beyond what other scopes offer. Siglent has obviously decided it makes sense to try to offer some similar capabilities in its new upper entry level scope instead of copying what everyone else is doing, which I find laudable. And even though the SDS2000X+ isn't a class of scope we normally buy, I can immediately think of a range of people I know which would love functionality like this and who don't need the large bandwidths (or the price tag) of a LeCroy scope.
Still this would target a niche market. Not sure if that is the right target for Siglent right now.
I wouldn't call (non-EE) engineering and science/research exactly a niche market.
Many non-EE parts of engineering use scopes, for example mechanical engineering, nuclear engineering (or pretty much anything which deals with radiation of some kind), medical engineering, chemistry and so on.
Then there is science, where scopes are used in a wide range of application from particle physics to astronomy.
I know this is an electronics forum, so most people here come with some kind of EE background, but don't let this fool you to think that scopes are pretty much just an EE's tool. Because they aren't.
The general purpose bench oscilloscope market is much more interesting if you can compete on price while offering the same features.
The general purpose bench scope market is pretty boring and crowded. Leaving LeCroy and Siglent aside for the moment, right now you can get a typical general purpose bench scope (say something in the 200-500MHz range) from Keysight, Rohde & Schwarz, Tektronix, Rigol, Iwatsu, Yokogawa, Hantek, GW Instek and Owon. That's nine vendors right there which all have different models in that category.
Now, if you take away the traditional big brands which are pretty expensive, there are still four B-brand vendors which serve the price conscious segment (i.e. hobbyists) - Rigol, Hantek, GWI and Owon.
That's quite some competition.
Now let's look at the vendors that specifically target the non-EE market with analysis scopes: LeCroy.
So there's that. In addition, LeCroy's analysis scopes (i.e. scopes which are not a simple rebadge of a standard scope from another manufacturer) start with the WaveSurfer Series, of which the WS3000z marks the bottom end. And being an X-Stream Lite scope, it may be cheap for what you get (and even more so when compared with other big brand scopes in the same class), but the smallest model (200Mhz 4ch) still starts at around $4.5k.
Most application outside the EE field require only modest bandwidths, so there definitely is room for a scope like the SDS2k+ with some advanced features.
Siglent has improved a lot over the last couple of years but IMHO they need to look beyond Lecroy's features (and limitations!) and have at least the same basic feature set the competition offers (simple things like allowing to use all the memory without needing to jump through hoops for example). Otherwise Rigol may catch up in a couple of years.
What features should that be that Siglent needs to add in your opinion, considering that Peak Detect and HiRes acquisition modes are apparently already offered in the SDS2kX+?
Not sure what you mean with "Rigol catching up" with Siglent. Rigol is much further, they have had high BW scopes for a long time (>5 yrs), they have had RF generators up to 6GHz for a few years, and for some time now are offering real-time spectrum analyzers up to 8GHz for a couple of years, based on their in-house developed ASIC.
Siglent just came out with its first 1Ghz scope and 3.2Ghz RF generator a year ago, it's spectrum analyzers are all standard type swept SAs with a BW up to 3.2GHz, and it uses COTS components in its products (no own ASIC).
So considering the facts, where exactly would Rigol be able to "catch up" to Siglent?
Besides, and without going into too much detail, a lot of Siglent's problems have actually been caused by their focus on being a better Rigol. It appears the co-operation with leCroy has given Siglent a better focus, and clearly Siglent's current products show the benefit of this co-operation.
Some of the engineers I have spoken to agree that Lecroy has some unique analysis features but if the competition would provide something similar they'd swap the Lecroy scopes in a heartbeat.
For what reason?
Also, the fact that, apparently, they still hang on to LeCroy because they offer functionality which clearly is important to them and which can't be found on other manufacturers' scopes, suggests that LeCroy is the one who does something right.
That is not a good position to be in as a manufacturer.
To be the only vendor for a functionality or feature your customers require is not a good position to be in? Seriously???
Recently I acquired a Lecroy Wavepro 7200A 7300A with tons of options but I wouldn't want to use this as a general purpose bench scope. It has so many features and options that it is getting cumbersome to setup for simple tasks. For example filtering; in some cases the filter doesn't even result in a filtered signal because the settings make the filter unstable. It really is geared towards analysis applications (besides showing a wiggly line). But maybe the new UI has been improved; I have not tried that.
News flash: WavePros aren't "general purpose scopes", they never were. These are special purpose deep analysis scopes which cost a truck-load of money and only make sense in applications which demand that kind of performance.
Size, noise and the limited trigger system alone make them a bad choice as general purpose scopes.
If you want a LeCroy scope which is suitable for general purpose use while offering advanced functionality then go for a WaveSurfer or WaveRunner, or a HDO.
And just to be clear, the poor suitability of the WavePro for general purpose work isn't specific to LeCroy, but applies to it's competitors as well. The Agilent DSO80k Series for example is equally horrible for standard tasks, and has some really annoying limitations in its sampling subsystem. The same is true for the DSO90k Series.
We got some Keysight UXR scopes recently, and while they are absolutely stunning scopes they are useless for your mundane poke-in-a-circuit stuff you'd use a bench scope for.
Looks like you bought the wrong scope for your needs.
