>One concern I've had about a DIY Logic Analyser for the Siglent is the possibility of scope damage if the scope logic connector isn't protected internally.
me too, but the original also uses 92k series resistor
hard to kill anything thru such high resistor value
That's a high value series R and agree not much concern about scope damage.
>Had you considered adding some active buffer circuitry
no, not yet, wanted to keep it cheap and simple.
just wanted to sell the pcb's for cost price and let people solder their own 0603 parts and 3D print the shell them self,
most people DIY people got a 3D printer too.
Assuming one has a 3D printer
I do find it hard to belive how they handle speeds down to a few nS at impedances in the 100k range,
most likely I will be using the LA for SPI and I2S and such, quite far away from this kind of speed
This must place the capacitance in the few picofarads range for fractional volts/ns at those impedance levels, impressive indeed!! Our use at present is just lower speed, like with RPi SPI & I2C bus and I/O while watching a few analog waveforms to/from ADCs and DACs, or stepper motor current/voltage waveforms, or Hall Effect Senors. So nothing fast like watching memory interfaces or such, just simple low-speed stuff. Normally we would just use a cheap standard logic analyzer but having the analog waveforms available is an important consideration since most of our work is more analog related than digital.
Edit: Taking a look at the Siglent SPL2016 (don't have one, never actually used or seen one, so all speculation) it seems they are splitting the interface task into a module that plugs directly into the scope slot and a pair of "pods" which host the actual connection wires which look like ~100mm long. A longer cable (likely are twisted pairs) connects the two pods to the base unit that plugs into the scope slot.
From this setup one might speculate that the pods host active buffer circuitry which convert inputs into differential outputs driving the twisted pair cable back to the base. The base hosts additional active circuitry to convert the differential back to single ended signal that drive the scope connector pins. If true then the ~100k and low capacitance as seen from the connection wires makes sense, as they are not directly connected to the scope connector, nor directly driving the longer cable, but driving some active buffer circuit in the pod. Maybe tautech, rf-loop, or someone with the SPL2016 can enlighten us
Best,
