More than 2 years I have RTB2002 (200MHz with full options + LA) in my homelab and recently purchased SDS2104X + (mainly due to the 4 channels).
To compare briefly:
RTB2000 + (compared to SDS2000Xplus)
- Very high quality of LCD, the viewing angles are large and the resolution is noticeably higher (1280x800 versus 1024x600)
- real 10 bits ADC over the entire band decide when to observe small noisy signals.
- excellent UI an control knobs responsiveness in any mode and any situation. High quality ("stepped") encoders. Very user-friendly and beautiful interface.
- high-quality rendering of the waveforms on the screen, no distortion is visible when changing the scale
- value labels on the grid axes facilitate quick visual assessment of signal parameters
- Built-in AWG with excellent parameters and capabilities
- A advanced "Pattern Generator" very useful in development.
- 1.25Gsamples for Logic Analyzer
RTB2000 - (compared to SDS2000Xplus)
- Not hackable! (the main disadvantage of these devices, all option very expencive!
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
- weak math (in the latest firmware version it was improved)
- few kinds of decoders (I2C, SPI, UART, CAN, LIN) and only 2 data signals can be decoded at the same time
- few types of triggers
- no 50Ω inputs and automatic probe attenuation detection
SDS2000X Plus + (comparatively RTB2000)
- A large number of triggers with broad capabilities
- A huge number of protocol decoders with a large number of settings
- 50Ω and automatic detection of probe attenuation
- Ability of arbitrary choice the colors for all types of waveforms (for me, as somewhat color blind, this is a very important option, on RTB2000 it is difficult for me to distinguish between yellow and green colors of channels traces - thanks to Siglent!)
- An interesting and useful (for some users) power analyze option.
SDS2000X Plus - (Compared to RTB2000)
- The poor quality of LCD, the viewing angles after RTB2000 are depressing, the resolution is lower.
- poor waveforms rendering (distortion when scaling, not very good work of "digital phosphor", there is something to improve)
- good user interface, but the responsiveness of the encoders knobs leaves much to be desired after RTB2000.
- no manual memory management and strange memory management algorithm for the history mode (with continuous loading into memory)
- only 500Msamples for the LA (Siglent, why???)
- weak in capabilities and parameters (no modulation, 125Msamples per second, indistinct ability to load captured waveforms into the AWG) built-in AWG (but only after RTB2000!
These are some thoughts after one month of working with SDS2000X Plus and more than 2 years with RTB2002.
The main advantage of R&S devices: there may not be very many functions and options, but everything that is, works flawlessly!
Max.
