Hello, I'd like to share some info related to web interface issues: after upgrading the scope I no longer have access to the remote interface using the instrument's IP on my notebook, but I found out that other Win10 units work flawlessly. The PC that is not capable of connecting using web browsers can do so using a VNC client other than the web browser noVNC feature.
I finally found out that the culprit seems to be Bitdefender Antivirus Free... If I uninstall it, everything gets back to normal, however if I reinstall it, connection is lost via web browser.
Strangely enough, if I disable all Bitdefender AV Free features from its control panel, there seems to be there is a component still active that blocks connection!.
I like BD AV Free as a protection layer, in case I find any configuration that helps solve this issue, I will post it for those who use same AV.
Regards!
