Author Topic: Siglent SDS2000X Plus - Bugs / Missing Features / Feature Requests  (Read 262019 times)
0 Members and 12 Guests are viewing this topic.
Offline BitBangingBytes
Re: Siglent SDS2000X Plus - Bugs / Missing Features / Feature Requests
« Reply #950 on: April 12, 2024, 05:49:32 am »
Didn’t try that
Offline smallfreak
  • Country: at
« Reply #951 on: April 12, 2024, 07:56:19 am »
Yea, I was closely reading Siglent’s directions last night…
I always wondered how rocket scientists are able recover their gadget a zillion miles away, when it choked on the last command, wrecked the antenna and drained the batteries.
If designed carefully, there is always another Plan-C, bypass, backdoor and spare circuit that can jump in
Offline KungFuJosh
  • TEAS is real.
« Reply #952 on: April 18, 2024, 08:52:36 pm »
There's a minor repeatable bug in 1.6.2r1.
After being in XY mode, exiting XY mode enables the digital channels on screen.
This hasn't happened in every instance, but it happens for me when I've been in XY for a while, and/maybe or when the scope is powered on in XY mode.
"I installed a skylight in my apartment yesterday... The people who live above me are furious." - Steven Wright
Offline 2N3055
  • Country: hr
« Reply #953 on: April 18, 2024, 09:26:50 pm »
When powered in X-Y and then you exit.
Already reported... 8)
The following users thanked this post: Performa01, tautech, KungFuJosh
Offline martin1959
    • Tele-Commies
« Reply #954 on: April 19, 2024, 07:24:34 am »
Has anyone tested the SigScopeLab software with an SDS2000X Plus?
I tried using this software.
Unfortunately, it does not work correctly with SDS2000X+. The timebase is not set correctly, it is in the range from 5 sec/div to 1 sec/div, regardless of what you set from PC. Maybe with the new firmware (when it released) the situation will improve, but for now this software useless for SDS2000X+ owners.
I had same problem using it on my Windows 10 PC which had the language and date/number format set to "German" (i.e. using comma "," as decimal separator). After changing Windows settings to use dot "." as decimal separator, as used in USA, the timebase settings were applied correctly. Maybe this helps.
The following users thanked this post: mathstudi
Offline KungFuJosh
  • TEAS is real.
« Reply #955 on: April 28, 2024, 12:41:09 am »
Is there a reason the screensaver doesn't shut off the backlight? Doesn't seem like it's doing a lot of saving if the backlight is still on.
Offline BillyO
« Reply #956 on: April 28, 2024, 12:43:52 am »
Is there any reason or evidence to think that a screen saver is even required for this kind of screen? :-//
The backlight is LED, so it's not likely to ever wear out, as it were.
Want to see an old guy fumble around re-learning a career left 40 years ago?  Well, look no further .. https://www.youtube.com/@uni-byte
Offline KungFuJosh
  • TEAS is real.
« Reply #957 on: April 28, 2024, 01:07:49 am »
I don't want to waste extra energy on the screen, especially when the screen is supposed to be off. Whether or not the screen itself needs it, I dunno.
Offline BillyO
« Reply #958 on: April 28, 2024, 01:09:53 am »
Understood.
Offline Wrenches of Death
« Reply #959 on: April 28, 2024, 01:14:01 am »
I've replaced a a large number of them in flat screen televisions. LED's don't last as long as it is commonly believed.
WoD
Offline BillyO
« Reply #960 on: April 28, 2024, 01:34:59 am »
WoD
So have I, but indeed in TVs, especially the cheap ones. they (can) overdrive them for brightness (which people seem to abuse).  There's no excuse for that in a scope screen where you are viewing a subdued image and from a meter distance or less.
Actually, what I replace most in TVs are capacitors in the power supplies.  Again, mostly in the cheap ones.
Offline tautech
« Reply #961 on: April 28, 2024, 01:42:07 am »
I'm into the habit of winding back brightness to 80%.......for no good reason other than not needing full brightness.
Offline BillyO
« Reply #962 on: April 28, 2024, 01:50:27 am »
I'm a 50% guy.
Offline KungFuJosh
  • TEAS is real.
« Reply #963 on: April 28, 2024, 01:52:32 am »
Do you have any idea about my question: Is there a reason the screensaver doesn't shut off the backlight?
Offline tautech
« Reply #964 on: April 28, 2024, 04:57:38 am »
Zip/zero.
Interesting proposal though, I wonder if the HW supports backlight OFF.
Offline BillyO
« Reply #965 on: April 28, 2024, 05:01:33 am »
It is under UI control, so that does imply the HW is subject to the SW.  This should be possible.
Offline krasimir.k
  • Country: bg
« Reply #966 on: July 08, 2024, 08:39:18 pm »
Siglent released the new FW 1.6.2R5 for SDS2000X Plus one week ago:
https://www.siglenteu.com/service-and-support/firmware-software/digital-oscilloscopes/#sds2000x-plus
Offline mon
Not the biggest fan of the new UI.
- No more antialiased text (I'll probably get used to it)
- "Off" state switches used to be greyed out, but now both on and off have a blue pill, which makes it hard to see at a glance.
- Scope probably takes about the same time to boot (I didn't time it...), but now it shows the UI before it's ready, and you need to wait an extra 10-15 seconds for it to work out what it's doing.
But... There are some nice things
- Switching off the bode plot seems faster, and waits for Recall to finish before swapping back to the normal UI (which is good)
- The timezone/time setting UI appears to no longer be horribly broken (resulting in unwanted offsets during initial time setup)
The following users thanked this post: alex_0331
