As using latest given FW.
Now getting repeated DSO hangings as saving a BIN file to external USB Stick. Error checking the USB did not showed any errors.
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
Is this known? Or any chance to the the upcoming FW?
Some more about the culprit:
- I set the probe as 0.10 as 20dB gain given from the amplifier.... and this causes to crash after certain samples. This means, NOT fully written 1Gs & 100M-samples and as stopped on 5% indication.
In other situation it looks as OK, even 0.1 probe value. So may a math issue
![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
- Setting the probe as 1:1 works
Update:
Getting repeated hangup's, I used FFT & 4x AVG as always on and C2 channel as Hide & 10ms & 1G/s to save 100M samples to a folder on the USB stick.
What works now after: - Formatted 16G USB stick on Win10 as 4k & FAT32
- Did a DSO calibration
- Saved now to any folders using C2 channel on as 0.1x probe settings (gain of amplifier) and FFT OFF
Hp
