To put things into perspective, here is the bug list of two manufacturers for two scopes that people seem trust implicitly without reserve.
Retail price for those 2 is easily 5x more..
I bold bugs directly pertaining to accuracy of data and basic functions of the scope...
Warning: lots of bugs, and serious ones... I hope people don't loose their trust... What do we do then?
FIRST:
Bug Fixes
This software revision includes the following Bug fixes:
- Corrected the D3000BDLA ultimate bundle license to include the NFC trigger option.
- Changed the My Support Subscriptions table to show N/A for the Support Expiration and Status of legacy perpetual licenses, versus Expired.
- Changed the Installed Options section of the instrument web page to show N/A for the Support Expiration and Status of a legacy perpetual license, versus Expired.
- Networked printing via CUPS print server works correctly
Bug Fixes
Corrected the NRZ serial decode from having an extra bit than the frame size when the Start-Bit is 0.-
Corrected “:MEASure:DELay:DEFine” for not accepting a definition that includes the “FALLing” edge parameter.-
Corrected the Reference Waveform data (.h5) from incorrectly saving data with twice the delay where is a delay on the displayed waveform.-
Corrected ":MEAS:SHOW?" always returning "1" regardless of the actual state.-
Fixed various LIN LDF file-parsing bugs.- Fixed various issues related to the N7026A probe.
Bug Fixes
An issue with handling CAN DBC signed integers has been corrected.–
Two channel measurements made with the N2820A probe are now functioning correctly. Bug Fixes
Digital channel skew has been corrected.
Horizontal scale indicators at the bottom of the graticule now update appropriately regardless of the chosen time reference.
An issue with calibrating an N275XA probe has been corrected.
An issue with the MEAS:RES query ignoring the count parameter has been corrected.
Bug Fixes
– Fixed an issue where the user’s selected language was not remembered after the power was cycled.
– Fixed an issue where an attached mouse would not operate correctly after the power was cycled.
Bug Fixes
Fixed an issue where in certain circumstances the Serial Lister would not properly display some UART data.–
Fixed an issue where in certain circumstances the Peak-Peak measurement was incorrect. Bug Fixes
Fixed incorrect DVM values in rare circumstances after toggling channel states.
– Fixed error messages when loading CAN FD .dbc files with data fields longer than 8 bytes.
Fixed crash when saving H5 files with long path strings.–
Improved I2C decode reliability when SCL is acquired on a digital channel.Bug Fixes
– Improved USB device mode stability when booting.
Fixed various LIN symbol file (LDF) parsing errors.–
Fixed 50Ω probe calibration issue with the Power Analysis application.– Improved performance when entering the IO menu.
Fixed FFT vertical units when using a 50Ω current probe. SECOND:
(not that this manufacturers dishonestly calls them "Improvements" not defects
... At least first one is honestly admitting they are bugs (defects) and owns the obligation for fixing them.
V01.600 Solved:
Trigger level knob has no function after using zoom or QuickMeas in roll mode and turn back to normal time base mode.
V01.600 Solved:
Wrong waveform data in zoom window when zoom is activated in roll initial mode and then the acquisition is stopped before the waveform window is complete.
V01.600 Solved: Sweep type 'Triangle' does not work correctly with RTM-B6.
V01.600 Solved:
Wrong clipping math waveforms, depending on history of math and source setup.
V01.600 Solved:
Sporadic incorrect data in math waveform.
V01.600 Solved:
Wrong value in numeric input keypad after clear and new input that starts with '-'.
V01.600 Solved:
Display of decode format bus 1 in ARINC 429 configuration window even when bus 2 to 4 is selected.V01.600 Solved: No function of 'Find Threshold' button in ARINC 429 configuration window.
V01.600 Solved:
A few instruments may irregularly show spikes in waveforms, depending on selected time base.
V01.600 Solved: I
n option RTM-K31 Switching Loss position cursors 3, 4 and 5 did not change measurement values.V01.600 Solved:
In rare cases, trigger jitter with positive trigger time and trigger point not in acquisition.V01.600 Solved:
Amplitude measurements with amplitude less than 7mV did not work.V01.600 Solved:
Wrong function of 'Wait on Trigger' Bit in status operation register after Break followed by Single.
V01.550 Solved:
Overshoot calculated 0 % with more than one signal period.V01.550 Solved: Sometimes Autoset sets wrong vertical scaling values with input frequencies lower than 500 Hz. It depends on control history.
V01.550 Solved:
Wrong horizontal position zoom if zoom tool used when menu is open.V01.501 Solved:
Universal rotary knob did not work in Horizontal menu on Zoom Scale.V01.501 Solved: Zero Adjust value in channel menu was lost with preset.
V01.501 Solved:
Wrong waveform offset in XY diagram with measurement and statistic tableV01.400 Solved: Noise on signal of analog generator remains after function change.
V01.400 Solved:
Firmware blocker after autoset in roll mode.V01.400 Solved:
Wrong waveform data display after stop in roll mode and QuickMeas.
V01.400 Solved:
Setting ZA15 option for active probe RT-ZDxx did not work.V01.400 Solved: Math function with inactive channels did not work.
V01.400 Solved:
Wrong data display in XY mode and roll mode with high resolution active.
V01.400 Solved:
Firmware blocker when waveform saving with 'Vis. Channels' or when saving bus table.
V01.400 Solved: Parallel bus displays more than one label in a large bus honeycomb.
V01.400 Solved:
No possible waveform scaling after single in roll mode.V01.400 Solved:
Measurement delay did not work with reference as source.V01.200 Solved:
For active high-voltage differential probes RT-ZHD as well as power rail probe RTZPR the zero offset of the probes was not corrected automatically by the instrument.V01.200 Solved: Probe attenuation was lost after preset with active probes.
V01.200 Solved:
In XY mode channel unit A was not considered for grid annotation in diagrams directly.
