SDS2104X, 1.3.7R5, Topic Persistence
This is a good instrument and a complex software, so the following comments feel like nitpicking, but anyhow:
- if you enable persistence, the first trigger event is not accumulated. That may not hurt for fast events, but for rare events it may matter.
- if persistence is enabled, and you change the trigger setting, persistence will be switched off, even if the display menu still shows, that it is switch on. You have to switch persistence manually off and on again, to get it back working. That is just another example of the many cases, that the menu does not reflect the internal state.
Best Regards, Robert
