These are the screenshots of my tests.
DUT is a UHF data receiver unit. It has 3 PLL IC`s (MAX2871) connectet to MCU via SPI. Each PLL has 6 write only register (32bit).
The signal is the initialization sequence requiered: R5 to R0 PLL1 (CS1),R5 to R0 PLL2 (CS2) and R5 to R0 PLL3 (CS3). For testing i repeatet this sequence at 10ms intervall.
The least 3 bits of 32bit words are defining the register address.
One scan, digital input, triggered on data (CS2,R3)
Long memory test, digital input, only CS2 decoded, triggered on data (R3),
Zoomed to R3, digital input
Analog input, triggered on CLK timeout, 3 PLL's* 6 registers
Zoomed to R3
18 full scans
Analog inputs with CS, trigger on data (R3 CS2), one full scan.
