After dealing with the device for a few days, I see some possible improvements:
Software:
1. Help Page: Enlarge the (or create a) cancel button. The small X in the
upper right corner is hard to hit with big fingers, and hard to
see on the Browser screen.
2. Allow the selection of the items in the menu column on the right side with the
universal dial. If you open that menu, the universal dial should allow
to move the selection up/down, and when you push it, that element is selected
for changing. Changing the trace intensity is already in the display tab.
3. An acceleration behavior of move buttons (e.g. horizontal, long lists, etc.
when the button is turned. Moving is rather slow.
4. AWG: Bursts, setting and triggering manual and by SCPI command.
5. Speed up UART Decoding, which is very slow for large memory depth settings.
6. Use mouse wheel for universal dial turns
Allow using the mouse wheel for changing the value when the focus in in a
field which is changeable with the universal dial. Using a (rf) mouse is very
convenient
7. Put all elements for a specific setting in one menu.
For instance window or runt trigger has the level and channel/timing
entries in two different menus, which have to be opened separately.
8. Option to increase vertical space. The title bar could for instance be
switchable via the display or utility button or collapse into a small button
in the left or right upper edge. It could be hidden when enabling Zoom.
Enabling/disabling the side bar menu could be by pushing the time/date
area which has no active purpose so far. Whether this information is needed
is questionable. There are other sources of time/date, and the LAN status
can be displayed in the LAN config menu.
Edit: Maybe only a "Full Screen" (toggle) button for the trace area. That would
interfere less with the actual layout.
9. Continuous move in history list. Moving the the history list with the up/down
arrows or the scroll bar should scroll the content continuously instead of
page by page.
10. Configure the timeout of auto trigger mode
Hardware:
1. Reduce the Fan noise. It's nod bad, but could be less.
2. AWG: It's not understandable why the rise/fall time of the arbitrary signals
is ~7 ns min, while the square signal's rise/fall time is at 24 ns. Add a
square wave arb template (and fix waveform import).
3. Where is WiFi?
Almost every piece of Electronics from 1USD devices on has WiFi? That's not
luxury, it's base level standard.
