Apart from this, for my
comparison thread I´ve used both mathchannels at the same time, for the first time..
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
Scope is getting slow when both channels are active, in my case both with FFT, more slowish it gets when measurings are active.
But that was to be expected, therefore no problem.
The following caught my eye:
-In exclusive mode, both traces are visible in one grid area, as expected(changed the trace colours for better visibility).
Wish: Having the split mode in such manner, that the two FFT traces will be displayed in different grid areas without the sources.
When you change from exclusive in split mode, in the upper grid area the two sources will displayed, in the lower the two FFT traces.
-Labeling: I´ve renamed the math traces in SDG1062X and SDG2122X, so far so good.
But the tables won´t be renamed, they still got F1 and F2 as name -
Wish: Tables could be also renamed.
