Author Topic: Siglent SDS2000X HD, missing Features and Bugs  (Read 82873 times)
Offline PartialDischarge
Re: Siglent SDS2000X HD, missing Features and Bugs
« Reply #50 on: October 21, 2022, 11:19:27 am »
Curious if anybody else has noticed this or if it may just be a bad power supply?
Nope mine is completely silent
Online Martin72Topic starter
  • Testfield Technician
« Reply #51 on: October 21, 2022, 11:22:57 am »
Yes in Standby you can hear the supply - How loud depends on your own sensivity.
Possible solutions were to use a load resistor at the cost of low standby power or to glue the "singing" components inside.
Or, best, totally powering off.
(Kierkegaard)
Offline Frankupthehall
« Reply #52 on: October 21, 2022, 11:55:55 am »
Glad to know I'm not crazy!
It sounds like a mosquito flying in your ear; intolerable. I used my phone to see where the hum was in the spectrum, attached for curiosity sake.
I can't imagine opening a brand new scope (brand new demo unit mind you!) and adding a load resistor to the power supply to fix something that shouldn't even be there in the first place. It would be an option if I had actually purchased the unit and was a few months into it's use before it showed up.
The following users thanked this post: jord4231
Offline jord4231
« Reply #53 on: October 21, 2022, 07:44:26 pm »
Mine has a high pitched sound when in standby, it drives me crazy my lab is fairly quiet.
Does the scope you have sound like mine? I've got an audio clip in this video towards the end. https://youtu.be/rvn4mzTLlnA
« Reply #54 on: October 21, 2022, 08:42:17 pm »
The whine during stand-by, that's it! Mine also does the same pitch "shoot into space" when pulling the plug; no point in making a recording or video myself since your video does a perfect job at pointing it out. I wouldn't be able to have the thing sit around plugged in for the same reasons, my office/lab space is rather quiet and it'd drive me nuts.
I suspect it's either some audible range pulse-skipping frequency in low power mode, some mechanical vibration in an XMFR in the PSU, or maybe even instability at low power. I doubt it's fixable in software unless perhaps a sub-system is left on during standby to add enough load to have the whine exit the audible range. Just my thoughts.
« Reply #55 on: October 21, 2022, 09:00:06 pm »
It´s a supply from meanwell:
EPS120-12
I think the coil from the output could be the "singer" (Pic)...
My solution is on the other pic.
(Kierkegaard)
« Reply #56 on: October 21, 2022, 10:07:46 pm »
What happens if you encase the coil in nail polish (if you have some handy)? That or varnish, something to stop the wires from moving.
I can appreciate the practicality of simply turning the bar off. But I'm of the opinion that a scope at this level should at least not whine about being off once and a while.  :-//
« Reply #57 on: October 21, 2022, 10:29:03 pm »
Mostly the psus of other scopes are hiding under the metal-case, so if they "sing" (not unsual behaviour under no load condition) you probably won´t hear it.
This one here is outside this case mounted.
Got the advantage, it couldn´t stray directly into the circuits, disadvantage sensitive people could hear something.
Sure it´s not nice, maybe siglent could do an exchange of "noisy" psus or let the warranty remain if it will be fixed by customer himself.
Edit see pics
« Last Edit: October 21, 2022, 10:33:16 pm by Martin72 »
(Kierkegaard)
Offline TopQuark
  • Country: hk
« Reply #58 on: November 11, 2022, 02:10:15 am »
Bug, or massive oversight.
Digital channels have sluggish response and low update rate, with waveform update rate of 16 wfm/s (100ns/div, 2kpts, 8 channel) observed by a couple of owners.
« Reply #59 on: November 12, 2022, 06:53:19 pm »
Here a wish, siglent can fulfill when they´re having nothing else to do or lost a bet or got a apprentice who needs a task... :D 8)
Decoder-feature:
Decoding of IR-transmitting codes, Like RC-5 and others for checking functionality of remote controls.
This would be absolute unique in the scope world, no one have this feature... ;)
So maybe someday in the future, when everything was done, before EOL a last present... ;D
Martin
(Kierkegaard)
Offline kripton2035
« Reply #60 on: November 12, 2022, 07:08:45 pm »
I have a problem with the time, more precisely the time zone.
if I set it to UTC, the time is correct and stays correct
if I set it to europe/paris as it should be, then set the time, it is ok if I restart the time is 1 hour too much
couldn't you set it with an ntp server ? it would be automatic.
I have the last actual firmware 1.2.1.1
(Kierkegaard)
Offline kripton2035
« Reply #62 on: November 12, 2022, 07:54:56 pm »
« Reply #63 on: November 12, 2022, 08:25:02 pm »
Therefore I´ve wrote in the linked post:
Gentlemen, we have a bug....
(Kierkegaard)
Offline kripton2035
« Reply #64 on: November 15, 2022, 07:26:15 am »
one feature I would like, is to have a way to measure calculated values.
like the formula editor for maths channels, but for advanced measurements.
measure built-in things, like width and duty cycle, and for example display also some calculated value with these two.
Offline kripton2035
« Reply #65 on: November 16, 2022, 07:24:42 am »
something I don't understand too is why the AWG is only a 25MHz one, and the AWG in the SDS plus is a 50MHz one ???
also this AWG doesn't have any modulation capabilities ? only simple straight frequency signal ?
it is then only usefull for making bode plots ?
Offline colorado.rob
« Reply #66 on: November 16, 2022, 02:32:30 pm »
Decoder-feature:
Martin
Add support for the SDS2000X HD to Sigrok.
https://sigrok.org/wiki/Protocol_decoders
https://sigrok.org/wiki/PulseView
You can do this with any of the existing supported scopes.
Now, finding a way to integrate sigrok & PulseView into their scopes natively would be truly mind-blowing.
Offline kripton2035
« Reply #67 on: November 16, 2022, 02:48:26 pm »
the sds2000(plus) is already detected by sigrok pulseview. so the HD should also be in. will test in a few hours.
edit: tried to connect to the 2000hd with pulseview using lan connexion (my computer is too far from the scope to use usb)
and I did not succeed to connect to the scope... using port 5025. any hint ?
edit2: after playing with pulseview trying to connect, just found the scope completely stuck. no button no touch screen. had to force restart.
« Last Edit: November 17, 2022, 08:18:03 pm by kripton2035 »
The following users thanked this post: colorado.rob
Offline kripton2035
« Reply #68 on: November 17, 2022, 08:01:24 pm »
if you hit the default button, it resets everything, but does not detect the 10x probes (the ones that are shipped with the scope)
you must unplug and replug the probe and it detects the 10x again.
« Reply #69 on: November 17, 2022, 08:30:12 pm »
You might try the SCPI commands listed here:
https://siglentna.com/operating-tip/spd-local-front-panel-lock-out-scpi-commands/
@tautech does the 2000HD have a front-panel lockout when using SCPI?
Offline tautech
« Reply #70 on: November 17, 2022, 08:38:43 pm »
Dunno, is it not in the HD programming guide ?
https://int.siglent.com/u_file/download/22_07_25/SDS2000X%20HD_ProgrammingGuide_EN11C.pdf
Out of office and unavailable for a few days.
Offline kripton2035
« Reply #71 on: November 17, 2022, 08:50:47 pm »
the web interface of the scope was stuck too. so not possible to send a scpi command. no other option than force restart...
Offline tautech
« Reply #72 on: November 17, 2022, 09:02:06 pm »
Hmmm, just went looking for HD drivers and there isn't any.  :-//
https://int.siglent.com/download/drivers/?ProId=63
Sinisa, can you check this stuff out as we still don't have an HD ?
« Reply #73 on: November 17, 2022, 09:03:38 pm »
(Kierkegaard)
Offline tautech
