Author Topic: Siglent SDS2000X HD, 12bit, 2GSa/s high definition oscilloscope serie.  (Read 344262 times)
markus_jlrb, MissBotox, david300m and 2 Guests are viewing this topic.
Offline egonotto
Re: Siglent SDS2000X HD, 12bit, 2GSa/s high definition oscilloscope serie.
« Reply #1175 on: August 01, 2024, 05:12:05 pm »
Hello,
KungFuJosh thanks.
Bad_Driver and other owners of the SDS2104X HD.
could you please post your results anyway. Then we would get an impression of how the individual devices scatter.
Stdev
(four channels, 1ms/div, 1GS/s, 10MPts, 50 Ω):
20MHz BW
1mv/div
1V/div
FULL BW
1mv/div
1V/div
Best regards
egonotto
The following users thanked this post: KungFuJosh, ozkarah
Online Bad_Driver
« Reply #1176 on: August 01, 2024, 05:19:55 pm »
I repeat the measurement tomorrow.
Now I have a glas of wine with my wife in the garden and be grateful for all your help!
The following users thanked this post: egonotto, 2N3055, KungFuJosh
Online Grandchuck
« Reply #1177 on: August 01, 2024, 06:46:41 pm »
Hello egonotto.  My 2204X HD
The following users thanked this post: egonotto, KungFuJosh, ozkarah
Offline gburdzin
« Reply #1178 on: August 01, 2024, 06:56:07 pm »
Here are mine:
« Reply #1179 on: August 01, 2024, 09:32:50 pm »
Do you by any chance have DVM meter on?
More specifically enabled DVM, pointing to CH1 and AutoRange ON in settings?  8)
Yes! That‘s it! Everything is now ok! And this explains all! Thanks to all who helped me with ideas and advice!
I wonder why the DVM was active after 2 factory resets and one firmware flash.
What can be useful in some cases is setting a User Default or even recalling your preferred Setup.
Save/Recall menu is where you can do either of these.  ;)
The following users thanked this post: egonotto, Bad_Driver
Online Bad_Driver
« Reply #1180 on: August 02, 2024, 08:53:52 am »
Here my measurements. It is worth mentioning that in my lab under the roof the temperature is 26 degrees.
Full bandwidth means 100 MHz since I have the SDS2104X HD.
« Last Edit: August 02, 2024, 12:13:23 pm by Bad_Driver »
Online Bad_Driver
« Reply #1181 on: August 02, 2024, 09:20:55 am »
There were some questions regarding the frequency counter. I checked it with my GPSDO. See attached.
Offline egonotto
« Reply #1182 on: August 02, 2024, 11:52:35 am »
Hello,
thanks to all of you.
@Bad_Driver: I understand that temperatures as cold as 26 Grad C in summer are not nice. I have a pleasant 28.8 Grad C :) You posted "Noise 50ohms Full 1V" twice and "Noise 50ohms Full 1mV" is missing.
After Wacken I will make an Excel file with the results.
Best regards
egonotto
P.S. The use of the Character for Grad makes a comment impossible.
« Last Edit: August 02, 2024, 12:02:05 pm by egonotto »
Online Bad_Driver
« Reply #1183 on: August 02, 2024, 12:14:17 pm »
Hello,
Best regards
egonotto
fixed! And enjoy Wacken!
« Last Edit: August 02, 2024, 12:22:36 pm by Bad_Driver »
Online KungFuJosh
  • TEAS is real.
« Reply #1184 on: August 02, 2024, 03:38:05 pm »
Can you do that test again, but also show the measurement stats at the bottom including Freq there, and the Counter popup box, like the one I showed in Reply #1157?
Thanks,
Josh
"I installed a skylight in my apartment yesterday... The people who live above me are furious." - Steven Wright
Online Bad_Driver
« Reply #1185 on: August 02, 2024, 04:17:01 pm »
Thanks,
Josh
Here we go!
« Last Edit: August 02, 2024, 04:19:34 pm by Bad_Driver »
Online KungFuJosh
  • TEAS is real.
« Reply #1186 on: August 02, 2024, 06:12:45 pm »
Damn it. Now I bought a GPSDO. 🤣
Online Bad_Driver
« Reply #1187 on: August 02, 2024, 07:11:08 pm »
I built my own some time ago.
https://www.eevblog.com/forum/projects/a-look-at-my-symmetricom-gpsdo-(ocxo-furuno-receiver)/msg3548229/#msg3548229
It runs now for 3 years and feeds my SDG2000, my SVA1032 and my HP53131a counter.
« Last Edit: August 02, 2024, 07:23:35 pm by Bad_Driver »
Online KungFuJosh
  • TEAS is real.
« Reply #1188 on: August 02, 2024, 07:18:36 pm »
Nice! That looks like a pretty serious project.
I just bought one for about $60 on Ali. If it sucks, I'll return it. 😉
Online Bad_Driver
« Reply #1189 on: August 02, 2024, 07:38:33 pm »
It´s a interesting topic, the GPS receiver guarantees long term frequency stability, a very good OCXO
and a good PLL is needed for low phase noise.
Online KungFuJosh
  • TEAS is real.
« Reply #1190 on: August 02, 2024, 07:40:20 pm »
I dunno how great it is. I bought it for the purpose of testing it. I have no other use for it, so that will be the entertainment.
Online Bad_Driver
« Reply #1191 on: August 02, 2024, 08:00:58 pm »
It‘s another rabbit hole   ;)
Online KungFuJosh
  • TEAS is real.
« Reply #1192 on: August 03, 2024, 01:27:12 am »
I did some more noise tests. Here they all are together.
The following users thanked this post: egonotto, Bad_Driver, ozkarah
Online Bad_Driver
I'm a little bit disappointed! I sold my SDS800 and my SDS2000X+ and spend some additional money for my 2000HD
and now I can't find the logarithmic freq. scale in FFT!
The SDS2000X+ got this feature with the latest firmware and the SDS800 had it from the beginning. My firmware of my 2000HD is up to date.
Has anyone information about upcoming improvements with the next firmware???
Offline Martin72
  • Testfield Technician
I have not the slightest doubt that this will also come for the 2000X HD.
Conversely, I wouldn't be so sure. ;)
(Kierkegaard)
