Author Topic: Siglent SDS2000X HD, 12bit, 2GSa/s high definition oscilloscope serie.  (Read 344341 times)
Offline dekagon
Re: Siglent SDS2000X HD, 12bit, 2GSa/s high definition oscilloscope serie.
« Reply #1125 on: July 09, 2024, 03:38:23 pm »
Do any of you already have one of these new black SDS2000X HD scopes in your hands?  :)
I'm curious if there are any differences between the first white and the current darkgrey generation and if so, what they are.  :o
I cannot believe that Siglent only change the outer shell and nothing more...  8)
Cheers Chris
Offline trackersoft
« Reply #1126 on: July 09, 2024, 03:42:11 pm »
New toy arrived. Got the bundle with it. Looking forward to using it!!
The following users thanked this post: egonotto, dekagon, Grandchuck, KungFuJosh, Costas07
Offline dekagon
« Reply #1127 on: July 09, 2024, 03:50:23 pm »
Oh, I almost forgot to mention:
Tadah! My Logic Probe SPL2016 arrived today! Great!  ^-^
Unfortunately I could test them first at the weekend :(
Cheers Chris
The following users thanked this post: egonotto, Martin72
Offline dekagon
« Reply #1128 on: July 09, 2024, 03:52:02 pm »
Heyhey the community is growing :)
Congratulations! I'm sure you'll be as excited as I am :)
Cheers Chris
The following users thanked this post: egonotto, trackersoft, ozkarah
Offline kripton2035
« Reply #1129 on: July 09, 2024, 04:35:23 pm »
first you have is the base line model is 200MHz instead of 100MHz ...
Offline Martin72
  • Testfield Technician
« Reply #1130 on: July 09, 2024, 05:00:12 pm »
If they had changed more, they wouldn't call it 2000X HD.
All 12 bit scopes are in the dark housing(6000pro H10/H12 excluded), now also the 2000X HD series.
(Kierkegaard)
Offline trackersoft
« Reply #1131 on: July 09, 2024, 05:20:57 pm »
I was expecting mine to be the dark grey but it is white (which is just fine with me!). It has been on order for months.
Offline Martin72
« Reply #1132 on: July 09, 2024, 05:33:55 pm »
These are leftover stocks.
(Kierkegaard)
Offline david300m
« Reply #1133 on: July 09, 2024, 11:26:02 pm »
I reached out to Siglent USA and they said nothing changed other than the case color.
The following users thanked this post: egonotto, dekagon, trackersoft
« Reply #1134 on: July 09, 2024, 11:44:21 pm »
Welcome to the forum.
It was quite evident in late Feb when SDS800X HD, SDS1000X HD and SDS3000X HD were released, all in black clothes, that SDS2000X HD might follow also....then a few spotted updated pictures showing SDS2000X HD in dark clothes too.
It makes perfect sense IMO that all the 12bit models have this point of distinction over their 8bit cousins.
Offline dekagon
« Reply #1135 on: July 10, 2024, 03:14:46 pm »
Thank you all for your replies. :)
Cheers Chris
Offline optotester
« Reply #1136 on: July 11, 2024, 09:36:35 pm »
Does anybody know why the bandwidth of the AWG is lower compared to SDS2000X non-HD series ?
It looks like they both use SAG1021 but one is limited to 25Mhz whereas the other is limited to 50Mhz sine.
Has anyone tried to change the NSP_limit_data to get back to 50Mhz ?
Maybe it was causing too much interferences ?
Anyway, 50Mhz was quite distorted on the non HD so it is not a big loss but I did miss that difference before buying.
Offline Martin72
« Reply #1137 on: July 11, 2024, 09:58:02 pm »
As far as I can remember, the AWG on the 2000X non-HD is integrated on the board, while the 2000X HD actually has a dedicated device installed via an internal USB port.
I don't know if they are the same, but the size of the dedicated board in the HD alone suggests that this is not the case.
(Kierkegaard)
The following users thanked this post: egonotto, optotester
Offline optotester
« Reply #1138 on: July 12, 2024, 06:33:26 am »
I think there was also a menu where it was listed as SAG1021 on the old 2K+ but I am not 100% sure. And it is possible, that indeed it was not integrated in the same way, even if they called it the same.
What I find a bit troubling to is that the SDS3K+ which uses the external SAG1021I, which goes officially up to 25Mhz, can go to 50Mhz:
https://eleshop.fr/catalog/product/view/id/5371/s/generateur-de-fonctions-siglent-sag1021i/category/530/
https://eleshop.fr/siglent-50-mhz-waveform-generator-software-option.html
So I am wondering if there is really an hardware limitation or more of a software lock.
« Reply #1139 on: July 12, 2024, 07:40:06 am »
Stop wondering.
Datasheet P14
https://int.siglent.com/u_file/download/24_07_01/SDS3000X%20HD_Datasheet_EN01B.pdf
Offline optotester
« Reply #1140 on: July 12, 2024, 07:46:16 am »
Interesting :)
So it is indeed more a software limitation than a hardware limitation. Looks like SDS1K which can use the external SAG1021I could benefit from that too.
Online KungFuJosh
  • TEAS is real.
« Reply #1141 on: July 31, 2024, 07:17:20 pm »
My new toy arrived today! I was pleasantly surprised by how perfectly it fits on top of the "tower of power (analysis?)."
I was also happy to see it came with a set of 4 SP5050A 500MHz probes...which are only mostly useless to me since I usually need at least a 400V limit, and also never go that high in freq. Still cool though! 😉
TBH I was a little disappointed by the metal handle. Maybe I was a too excited for it? But I thought it was this big huge thing, and the handle just matches the rest of the case. Not shiny, didn't give me handy or anything. I guess there was simply too much hype about the metal handle.
The scope feels faster and more responsive than my previous Plus model. Me likey.
I updated to the latest firmware and self cal only took about 5 minutes. I noticed they only made the 16LA option free in this model in the fw update. I guess only the models with an external FG get it added free.
Thanks,
Josh
"I installed a skylight in my apartment yesterday... The people who live above me are furious." - Steven Wright
The following users thanked this post: Performa01, egonotto, ebastler, Martin72, ozkarah
Offline Martin72
« Reply #1142 on: July 31, 2024, 07:26:05 pm »
 :-DD
(Kierkegaard)
The following users thanked this post: egonotto, KungFuJosh
Online KungFuJosh
  • TEAS is real.
« Reply #1143 on: July 31, 2024, 07:32:06 pm »
:-DD
I do plan on doing the demo board over again. I pulled out the board and my fake SPL2016 as soon as I ordered the scope. 😉
Offline egonotto
« Reply #1144 on: July 31, 2024, 07:35:04 pm »
Hello,
are dust caps included with the three BNC sockets on the back?
Best regards
egonotto
Online KungFuJosh
  • TEAS is real.
« Reply #1145 on: July 31, 2024, 07:36:59 pm »
Yes, all BNCs had dust caps on them.
Offline ebastler
« Reply #1146 on: July 31, 2024, 07:48:17 pm »
Impressive setup! The scope looks like it wants to be bolted down when balancing on that tower, or at least tied to a safety rope.  ;)
I hope the metal handle is at least nice and cool to the touch? As long as one does not fondle it for too long, of course... :)
Offline egonotto
« Reply #1147 on: July 31, 2024, 07:54:34 pm »
Hello,
I didn't have them, is that a sign that my device is a return?
Best regards
egonotto
Online KungFuJosh
  • TEAS is real.
« Reply #1148 on: July 31, 2024, 07:56:53 pm »
Thank you! I know you have more toys than me though. 😉😉
There's a strap on the back that will be connected, and Velcro on the feet will be connected also. I don't trust gravity either.
It's like 31°C today, so the handle wasn't even cold. 😭
« Last Edit: July 31, 2024, 07:59:20 pm by KungFuJosh »
Offline Martin72
« Reply #1149 on: July 31, 2024, 08:04:50 pm »
My “Tower of Power” is just waiting for the lower compartment to be filled again with the successor to my SML01. ;)
(Kierkegaard)
The following users thanked this post: Performa01, egonotto, KungFuJosh
