Quote from: egonotto on April 08, 2024, 11:28:02 amHello,now my SDS2XHD-BND has also arrived. Getting the licenses took some work. When I plugged in the USB dongle, I had problems because my SDS2104X HD crashed. When installing the SDS2XHD-BND LIC files ?
With my SDS2104X HD I only get 97 Mpts per channel
Quote from: egonotto on April 08, 2024, 10:25:43 pmWith my SDS2104X HD I only get 97 Mpts per channel"Record length up to 200 Mpts/ch, 400 Mpts in total for all 4 channels"
Correct however it need be pointed out the 200 Mpts is available to a single channel or when 1 channel is on each ADC and as each ADC has 200 Mpts available this will be divided down to 100 Mpts when 3 or 4 channels are in use.
Yep, Rob is immensely valuable to the entire Siglent community, helping everywhere well out of his physical area of responsibility. We all are deeply indebted to Rob for his continual help and guidance with Siglent products Folks considering various equipments should consider the Built-In Siglent" help Rob represents here Best,
Quote from: tautech on April 08, 2024, 11:20:41 pmCorrect however it need be pointed out the 200 Mpts is available to a single channel or when 1 channel is on each ADC and as each ADC has 200 Mpts available this will be divided down to 100 Mpts when 3 or 4 channels are in use.Yup, but it's like they say: why type something out when you know Rob will do it for you? 😉😉
Hello,many oscilloscopes from other companies have much more segmented memory than in non-segmented mode. E.g. R&S RTB, RTM, RTA, MXO 4, MXO 5, Rigol DHO1074, Micsig MHO3, Cleverscope CS328A.Best regards egonotto
.... and some scopes you should recheck the datasheets for.
Anybody see anything missing or inaccurate?
Quote from: KungFuJosh on April 09, 2024, 12:41:11 am.... and some scopes you should recheck the datasheets for.Hello,which scope do you mean? Perhaps MXO 4 or MXO 5?RTB, RTM and RTA have far more than twice as much segmented memory. RTA has about 2 GSa segmented memory.Cleverscope CS328A uses double buffers and makes the second buffer available for segmented memory.The MHO3 has about 2 times 860 MSa of segmented memory.If I remember correctly, I have more than 300 MSa of segmented memory in my DHO1074.Best regardsegonotto
Hello,in segmented memory mode I always get less than 100 Mpts/channel with four channels.Am I doing something wrong?According to 2N3055 you get much more with the SDS3000X HD: "It is 159 Mpts with 1Mpts length, per channel". With my SDS2104X HD I only get 97 Mpts per channelBest regardsegonotto
I am concerned here with the segmented memory.
Quote from: egonotto on April 09, 2024, 03:07:11 amI am concerned here with the segmented memory.Oh, it's way past my bedtime, I missed that part. Somebody else should chime in on the segmented memory comparison. I find it hard to believe that those other scopes are better based on the memory depth comparison, but I don't really know anything about comparing segmented memory and regular memory depth.
I would describe this as normal, it has to be initialized once by a restart.
We normally install the license keys once and then just forget about them.Yet it just so happens that just recently I decided to bring some of my scopes up to date and install the missng licenses (e.g. of options that haven't been available back when I got the instruments), therefore I remember very well how it goes.The instrument prompts you to do a restart after each and every license key that has been accepted. You can ignore that prompt and install another license immediately, yet after entering the last key you should perform the requested restart.
Quote from: Performa01 on April 09, 2024, 02:31:16 pmWe normally install the license keys once and then just forget about them.Yet it just so happens that just recently I decided to bring some of my scopes up to date and install the missng licenses (e.g. of options that haven't been available back when I got the instruments), therefore I remember very well how it goes.The instrument prompts you to do a restart after each and every license key that has been accepted. You can ignore that prompt and install another license immediately, yet after entering the last key you should perform the requested restart.I had the USB stick loaded with the 8 license files that were included with the LA bundle, and in my case there definitely were no prompts between each license. They all were installed automatically one after another once I started the installation.
