Yes, the PA came with it. Now i need to get current probes.........
Good tip, with the USB in the back!
There are some things that they could have done differently or i haven't figured it out yet:
- For the scroll bar from the picture, that apears when the menu has more items than the screen can show, what would i do without the mouse? I mean also with the mouse you have to go with it off screen so you can greb the bar and reach the end of the menu.
- in FFT mode would have been great if it would calculate THD. even the cheapest picoscope does it.
- I haven't done anything with the PA mode yet, however i saw it can calculate efficiency. Would be great if it could also controll an electronic load and plot out stuff versus ouput current, like efficiency vs ouput current, ripple vs output current
- Is there a way of retrieving files out of it? i mean it has the webserver, but if i want to save a picture with a white background, i would have to save it on the internal memory and copy it via USB sitck? if this is the case this is kinda so 2001.
