Please can you explain more about this.
Yesterday I wanted to recreate TopQuark's crash with the scope in zoom mode, I activated two channels and put one signal on each.
Then activated the zoom mode and nothing happened, everything went well.
Then I thought OK, add some measurements, maybe something will happen.
Now I'm used to lecroy menu navigation for two decades...
So I had done it "as always" and selected first the source and then the parameter.
In the case (by chance) RMS and then from channel 2.
Then I wanted to get from channel 4 also the RMS value displayed and wanted to do it again as usual, first the source, then the parameter.
And that had driven me crazy yesterday.
When I had changed the source to channel 4, the previously selected rms from channel 2 was changed to 4.
OK I thought, then select rms first, then the source.
Then when I pressed rms, everything was gone....
Why the hell ?!
Today after sleepimg and working...
...I took the manual and lo and behold, you can't just set something, you have to pay attention to the mode, simple or advanced.
![Tongue :P](https://www.eevblog.com/forum/Smileys/default/tongue.gif)
And only in the advanced mode you can proceed as intended and assign the parameters to individual sources....
The problem was once again RTFM - But honestly, intuitively just quickly set something is not there with the siglent, this is much easier with lecroy, because lecroy does not have such a bells and whistles as simple and advanced...
Especially with the word SIMPLE you should expect....
![Cool 8)](https://www.eevblog.com/forum/Smileys/default/cool.gif)
But well, nothing is perfect and now I have learned.
