Author Topic: Siglent SDS2000X HD, 12bit, 2GSa/s high definition oscilloscope serie.  (Read 344783 times)
0 Members and 12 Guests are viewing this topic.
Offline kripton2035
Re: Siglent SDS2000X HD, 12bit, 2GSa/s high definition oscilloscope serie.
« Reply #400 on: November 04, 2022, 10:27:43 am »
I´m still hoping there will be a discount offer for the probes only someday.
Yes, there will be DIY alternatives, but I like to have the "original".
But not for this price. 8)
yep a digital probe clone on ebay is only $50 ...
... and you have to hack the LA licence...
The following users thanked this post: jord4231
Offline kripton2035
« Reply #401 on: November 04, 2022, 10:29:24 am »
Having some fun with writing apps for the scope:
/usr/bin/siglent/usr/mass_storage/U-disk1 # ./rusty_siglent_app
Hello, world!!!
would you like to publish the source code of this "hello" app ?
Offline TopQuark
  • Country: hk
« Reply #402 on: November 04, 2022, 11:04:06 am »
Hello, world!!!
Sure, you need the Nix (https://nixos.org/) build system with flakes enabled (https://nixos.wiki/wiki/Flakes), and only need to run
nix develop to reproduce my my cross compile environment and
nix build   to cross compile the correct binaries.
product_rcs_begin.sh contains the recommended contents of /usr/bin/siglent/product_rcs_begin.sh on your scope's filesystem, so that you can telnet and ftp to the scope after the scope boots up.
upload.sh is a helper script to upload the compiled binary file to the scope and run it.
The following users thanked this post: kripton2035
Offline TopQuark
  • Country: hk
« Reply #403 on: November 04, 2022, 11:15:29 am »
Also, here's the scope's devicetree in case you feel like interfacing with the fpga and poke around the DMA busses...
Offline TopQuark
  • Country: hk
« Reply #404 on: November 10, 2022, 08:39:48 pm »
Can anyone with the SDS2kHD and a digital probe set verify what I am seeing? It seems like the digital channel capture rate of the HD is very very slow compared to the SDS2k Plus.
I am only getting 16 wfm/sec on the HD (100ns/div, 2kpts, 8 channel), whereas the Plus is achieving 2.3k wfm/sec with the same settings. :scared:   I have reset the scope a few times and repeated the tests, and the results are the same.
Also on the HD, fast mode in the acq menu cannot be activated with digital channels on, whereas that's possible on the Plus.
Edit: I am using the original Siglent digital probes, so it shouldn't be a hardware problem
« Last Edit: November 10, 2022, 08:41:20 pm by TopQuark »
Offline Martin72
  • Testfield Technician
« Reply #405 on: November 10, 2022, 08:53:53 pm »
Sounds like a bug to me - Want you place it in the bug/feature thread ?
(Kierkegaard)
Offline TopQuark
  • Country: hk
« Reply #406 on: November 10, 2022, 09:01:33 pm »
Just not sure if I'm doing something silly and accidentally killing the performance of the digital mode. Want some confirmation before I make a big fuss out of it.
As a sanity check, I just verified the analog waveform update rate, and I can get the advertised 100k wfm/s with the analog channels.
Offline Martin72
« Reply #407 on: November 10, 2022, 09:14:20 pm »
I do have the MSO option, but unfortunately no logic probes... :(
Maybe tautech can test it when he got a HD there.
(Kierkegaard)
« Reply #408 on: November 10, 2022, 10:00:38 pm »
Sorry, no SDS2000X HD here.
Offline TopQuark
  • Country: hk
« Reply #409 on: November 10, 2022, 11:32:57 pm »
@tautech, is it possible for you to reach out to Siglent and ask them what we should expect out of the HD in terms of digital channel waveform update performance? Thanks
Offline Martin72
« Reply #410 on: November 10, 2022, 11:56:46 pm »
Surely not 16wfms/s...
(Kierkegaard)
Offline 2N3055
  • Country: hr
« Reply #411 on: November 11, 2022, 12:22:15 am »
Yeah I get 16wfms/s too.
Well in that mode it handles double the data and data is routed slightly differently.. It has to be in Slow mode, because it has to capture buffer and process all of it before going to next one. It cannot just do bursts like in Fast mode.
Martin, you can check without probes, enable digital channels, and connect 100KHz (or more) signal to CH1 and trigger on that..
@TopQuark, sorry, what FW are you running..
Offline Martin72
« Reply #412 on: November 11, 2022, 12:26:41 am »
OK, try it later on friday.
TopQuark also got the 2000X+, with 2300 wfms/s...
(Kierkegaard)
« Reply #413 on: November 11, 2022, 12:34:40 am »
Sorry, no.
First consult datasheet and manuals then wait for feedback from the few beta testers watching this thread as they have more direct contact with product managers than anybody.
I do note max sampling is listed in the datasheet as 500 MSa/s and Memory Depth 50 Mpts/ch although analog memory settings might also impact on WFPS performance. Those with these instruments at their fingertips are best qualified to research this issue.
Offline TopQuark
  • Country: hk
« Reply #414 on: November 11, 2022, 02:06:17 am »
Well, good to know the problem is reproducible, thanks for checking. I am running the latest 1.2.1.1 software, with FPGA version 2022-07-08.
On the SDS2504X Plus it is significantly faster at 2300 wfm/s, digital phosphor works, where you can see the digital trace overlap, the responsiveness is much better, and fast mode can be toggled on in the acquire menu. It is almost like the digital channels are processed in software on the HD, whereas the Plus processes it in hardware.
Sorry, no.
No worries, it was a long shot anyways. I'll file the issue in the bugs thread and see if it gets picked up by anyone.  ::)
Offline kripton2035
« Reply #415 on: November 11, 2022, 09:07:07 am »
before ... and after...
I see things ... better !
The following users thanked this post: 2N3055, TopQuark, Martin72
Offline Martin72
« Reply #416 on: November 11, 2022, 01:08:16 pm »
Hm-hm..Sounds "interesting"...
Haha, can´t do this, I didn´t got a second scope here for wfm measure, totally forgotten. :P
(Kierkegaard)
Offline rf-loopTopic starter
« Reply #417 on: November 11, 2022, 02:17:36 pm »
Yes it is DSO like in this. Acquistion, display, next acquistion, display.
If Bus display is off around 16wfm/s max
And with bus decode, it slows bit. here example 8bit bus
With Auto memory (Analog channel length 400pts) around 12wfm/s
With Fixed memory (Analog channel length 20Mpts (400pts displayed and rest outside of screen) around 11wfm/s
Analog channel 40MHz and digital 8 channels all get parallel 20MHz
wfms measured using other scope.
Btw, if wfm/s is lot of faster and signal is changing, how you think what bus decode is displaying.. only way is that it capture just single and display its decoded result and after then next capture... no DPO stacking overlaid (for what).
How it can read if it works like DPO where is severe acquistions overlaid in every display refresh. Think twice.
« Last Edit: November 11, 2022, 04:15:47 pm by rf-loop »
Offline Martin72
« Reply #418 on: November 11, 2022, 04:24:01 pm »
And what´s the explanation for that the 2000X+ wfms/s is about 140x faster in the same situation ?
(Kierkegaard)
The following users thanked this post: kripton2035, Jacon
Offline TopQuark
  • Country: hk
« Reply #419 on: November 11, 2022, 08:40:50 pm »
Hi, shot a quick video showing the differences between the Plus and the HD in digital mode. It demonstrates the speed difference, and that the Plus does have digital phosphor working.
https://youtu.be/tsYzZ_vCalo
The following users thanked this post: kripton2035, egonotto, Martin72
Offline baldurn
« Reply #420 on: November 14, 2022, 12:24:39 pm »
I am considering buying but can I hack it? How? I am not finding anything...
Offline TopQuark
  • Country: hk
« Reply #421 on: November 15, 2022, 03:42:16 am »
Yes, you can hack it, there's a few owner of the HD who have fully unlocked their scopes. As to how, I am not the one to be able to answer, look through the thread to see who's the mastermind.  ::)
Offline elimenohpee
« Reply #422 on: November 15, 2022, 11:02:43 pm »
I'm with you, I'm in the market for a scope of this caliber. I'm up for buying one but if it's not exactly hackable, I'm leaning to the SD2000x+
Offline Martin72
« Reply #423 on: November 15, 2022, 11:16:55 pm »
Actually you get a bandwithupgrade and the decoders for free when buying a HD, just saying... ;)
IMHO a easy to hack guide won´t be published because it is not easy to hack.
But it could be done, that´s assured.
The rest TopQuark have already "said" in his last post.
(Kierkegaard)
Offline baldurn
« Reply #424 on: November 15, 2022, 11:34:12 pm »
Yes it is a good offer but I would still need to go for one the more expensive options for this not be a downgrade. And that would put it out of my budget range :-(
I did manage to hack my SSA3032X-R and that was not too easy either. I can do Linux all day long. May even be willing to open it up to connect to the serial. But I do not want to try to hack it all on my own. Then it becomes a project with no guarantee that I would succeed and I will rather spend my time on something else.
