Author Topic: Siglent SDS2000X HD, 12bit, 2GSa/s high definition oscilloscope serie.  (Read 353416 times)
0 Members and 12 Guests are viewing this topic.
Offline Bad_Driver
Re: Siglent SDS2000X HD, 12bit, 2GSa/s high definition oscilloscope serie.
« Reply #325 on: September 15, 2022, 01:59:02 pm »
The competitor shows up - now with US prices.
https://www.rigolna.com/products/digital-oscilloscopes/hdo4000/
https://www.rigolna.com/products/digital-oscilloscopes/hdo1000/
With due all respect, not really a competitor..
It has 12 bit specified and that is all.. We have yet to see how it works.
It is also missing a lot of stuff.. Let's see how it works first, before passing opinions..
I agree but let's see what Dave will find out. Let us stay fair to the new kid on the block. We only know what we see in the data sheets.
I'm pretty happy that I decided for the SDS2000X+ two years ago and not for the Rigol MSO5000.
For hobby the SDS2000X HD is too expensive for me.
But a second entry level 12 bit scope may be an addition for some cases on my bench?
Offline mawyatt
« Reply #326 on: September 15, 2022, 07:26:48 pm »
Anyone know which ADC Siglent is using in the HD and the SDS6000? This may have been asked/answered before, but couldn't find such.
Thanks in advance.
Best,
~Wyatt Labs by Mike~
Online Martin72
  • Testfield Technician
(Kierkegaard)
The following users thanked this post: mawyatt
Offline danils
« Reply #328 on: September 15, 2022, 08:59:14 pm »
Hi Guys,
Following this thread and your advice, I traded in my Agilent Infiniivision 2000-X and got the SDS2000X HD.
I am loving it so far, I am shocked how much detail I got testing for some disturbances debugging a I2C line.
I continue reading this useful thread and post some questions, eventually! :)
Greetings!
Daniele
The following users thanked this post: Martin72, jord4231
Online Martin72
« Reply #329 on: September 15, 2022, 09:14:24 pm »
You´re very welcome!
(Kierkegaard)
The following users thanked this post: danils
« Reply #331 on: September 16, 2022, 10:43:55 pm »
Good spotting  :-+
New firmware for SDS2000X HD models:
https://int.siglent.com/upload_file/zip/firmware/Oscilloscope/SDS2000X_HD_V1.2.1.1_EN.zip
Version V1.2.1.1
40MB
Release notes:
Math: filter supported
Optimized knob acceleration
Force trigger strategy changed
Fixed several bugs
Scope gets confused about time zone and time
Digital Channels display bug with >5M memory
Online Martin72
« Reply #332 on: September 16, 2022, 11:05:27 pm »
Oho, will try it "tomorrow" (saturday meaning)...
Filters ? Yeah !
Personally for me the LP is interesting - Will it allow to filter out a 400hz sinewave from 10khz carrier...
(Kierkegaard)
Offline jord4231
« Reply #333 on: September 17, 2022, 02:34:14 am »
Short video I did on Quadraphonic vinyl I used my SDS2104xHD in the video to show the carrier frequency https://youtu.be/PzAJy8G8_H0  :blah:
The following users thanked this post: Bad_Driver, danils
Offline jord4231
« Reply #334 on: September 17, 2022, 03:21:19 am »
I just updated to the new FW mine wouldn't recognise any usb stick I had to do it over the web control via lan
Online 2N3055
  • Country: hr
« Reply #335 on: September 17, 2022, 08:23:48 am »
Tips and tricks:
These scopes don't have Force trigger button. Which is something I miss. When you are in Single mode, if you press Single again, it will force trigger... But no classical Force trigger button for Normal mode.
Buuut.......
If you touch screen area in upper right where there is Siglent logo trigger status and frequency counter, magic happens...
Pressing that area was assigned to Force trigger function. It works in Normal and Single mode..
« Last Edit: September 17, 2022, 10:41:01 am by 2N3055 »
The following users thanked this post: jord4231, danils
Offline noisyee
  • Country: cn
« Reply #336 on: September 17, 2022, 10:04:21 am »
WOW, that magic not even mentioned in the manual :-+
Actually you can have a dedicated Force trigger button if you assign Force Trigger function to the Quick Action button. Works both in Single and Normal mode, too.
Online 2N3055
  • Country: hr
« Reply #337 on: September 17, 2022, 10:39:38 am »
(Attachment Link)
Yes that too.. but this is always there and dead simple...!!
It'll be in a manual soon, but i think it was important enough to share ASAP...
Offline rf-loopTopic starter
« Reply #338 on: September 17, 2022, 10:50:38 am »
Mostly I do not use touch panel. I use mostly mouse. Because mostly test circuit (DUT) is on table and example in this case oscilloscope is behind this DUT.
Just what 2N3055 told it also works with mouse, just click it instead of touch..
Then it is also available if click mouse over bottom Trigger info. It open panel where is now also Force trig. And naturally user can move this small panel to place he want.
Example now I have "Bob Pease" style circuit here  around table with some other meters also around it and circuit have also high voltage (just open wires all around and hundreds of Volt, but up to only 1kV in this case) and oscilloscope is just behind circuit so that when I do some adjustments in circuit "on the fly" I do not want turn my head for look signal or adjust scope.
With full mouse control it is really really nice to do work and no need use hand over  DUT to adjust(in this case bit danger DUT). And now Force Trig is available just under my finger.
In this test case I need many times wait long long time after signal meet trigger. But sometimes I want look what is going on when no trig.  Just click mouse.
The following users thanked this post: 2N3055, jord4231, danils
Online Martin72
« Reply #339 on: September 17, 2022, 05:21:59 pm »
Did the upgrade, let it warming up for self-cal.
After first rebooting, there were things to see that makes my pants wet.
But as I "touched" on it, it vanished for ever.
I swear I could hear a laugh:
Nanana-Na-Naaa.... 8)
(Kierkegaard)
« Reply #340 on: September 17, 2022, 06:02:45 pm »
It's not worth looking at all the little things so closely.   ::)
« Last Edit: September 17, 2022, 06:07:04 pm by rf-loop »
Online Martin72
« Reply #341 on: September 17, 2022, 07:18:27 pm »
LOL.
(Kierkegaard)
Online Martin72
« Reply #342 on: September 18, 2022, 03:02:21 pm »
Don´t know if this is a bug or not, therefore posting it here.
Soon as my HD arrived I took the bodnar pulser on it and wonder about the "stop and go" behaviour of the waveform displaying.
Never saw this before, thought this could be gone with a new firmware but it wasn´t so I post it.
"Stop and go" means, the displayed waveform is somekind of moving, then stopped shortly and the dots are visible, then the same again, periodly but not exactly the same time.
If I take the SDG1062X and feed 10Mhz Square into the scope, I don´t get this behaviour.
(Kierkegaard)
« Reply #343 on: September 18, 2022, 08:05:30 pm »
Acquire menu = Dot mode.  ;)
Online Martin72
« Reply #344 on: September 18, 2022, 08:22:36 pm »
It´s not that easy..
https://youtu.be/69YJ2UcYTgM
(Kierkegaard)
« Reply #345 on: September 18, 2022, 08:31:49 pm »
Auto or Fixed Mem mode ?
Fixed Sample rate ?
What happens after you Default the scope ?
Online Martin72
« Reply #346 on: September 18, 2022, 08:41:41 pm »
Auto Mode, tried several things without effect.
Waveform seems to change between dots/vectors periodically and "paused" inbetween.
I´m pretty sure the Xplus fully armed to 500Mhz didn´t show this behaviour.
Will take the bodnar pulser to work, test it on the HDO 350Mhz and the Waverunner 500Mhz.
(Kierkegaard)
« Reply #347 on: September 18, 2022, 08:45:05 pm »
Will check on the 6204A today too but it's currently packed in the SUV ready for a visit to a client so will pack the Leo pulser too and grab a screenshot or at least try and find if it does anything similar.  :-\
TTYL
Offline miro123
« Reply #348 on: September 18, 2022, 08:48:40 pm »
Did you try to swap the scope?  Do you see some termination issue with another scope?
Do you use 50Ohm input?
What type of acquisition mode is used ? peak detect etc?
It seems that the scope reference frequency pretty close to Bodnar signal - this make such effect visible for humans
Online Martin72
« Reply #349 on: September 18, 2022, 09:12:43 pm »
On my former SDS2354X (500Mhz) I didn´t got this behaviour, 99% sure.
Before on the Rigol MSO5000 350Mhz the same, not such behaviour.
Can test it at work with lecroy WR9054(500Mhz, 8Bit) and HDO6054A (350Mhz, 12Bit).
Aquisition was normal, memory management auto, termination 50 Ohms.
It must have to do with the bodnar because of its fast risetime of 40ps.
10Mhz squarewave from my sdg1062X generator won´t have this effect (or very less), its risetime is appx 3ns.
« Last Edit: September 18, 2022, 09:40:38 pm by Martin72 »
(Kierkegaard)
