HI GUYS,
It would be appear that we got a bit carried away on the other forum....
Here.. (Perhaps from around Page 60 onwards)
https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-series-oscilloscopesand after unlocking our MSO5000 scopes from Factory to 350MHz with all Options we were all chuffed,
But then we unlocked it further to 500MHz
After that there was some debate as to whether the changes were just cosmetic or actual and realized.
So we started testing and uploading screenshots, the results were interesting.
I'm still in the process of testing to see if the MSO5000 can go higher than 500MHz and from what we can tell so far (Long story short) I can indeed go to 900MHz and up to 1.1GHz but not beyond
THE PURPOSE OF THIS TOPIC IS....
1. Go Nuts with scope bandwidth Analysis
2. To keep the other forum on Topic
3. Feel free to add analysis of other scopes, But try to keep it mainly on Rigol MSO5000 if possible=======================================================================================================================
RESOURCES :
Here is the Main Hacking Post (The Big one)
https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-series-oscilloscopesHere is my shorter version of it that contains the activation procedure
https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-dr-mefisto-licensing-method/Here is the link to the deep dive video series that i created. (This has nothing to do with activation, it's more for people who want to know how to completely use their scopes in depth)
and this thread with complement that video series.
https://www.eevblog.com/forum/testgear/post-hacking-rigol-mso5000-post-hacking-tutorial-deep-diveHere is the MSO8000 Series link where ASP
@traxpalicaru has put in some awesome work to get us to where we are , this link contains historical versions of the python scripts
https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso8204-mso8000/=======================================================================================================================
Now that the formalities are out of the way. LET THE SCREENSHOTS BEGIN .....
OFFICIALLY this Topic picks up from page 63 of this link
https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-series-oscilloscopesCURRENTLY
@ 6SN7WGTB Posted the Frequency response testing of his MSO5104 (In the Attachment)
@Odd-Job , we thought odd job was a rockstar who had a crazy Sig Gen to die for , But it turns out he just bought an Amazon cheapy so we have lost all respect for odd job
I'm even considering banning him from this thread until he gets a better Sig Gen
@ Me Apparently i was told that i was a knob for using RG-6 Coax (75 Ohm) for testing the frequency response of my MSO5000
my defense was, it's all i had lying around. In an attempt to regain my honour i have gone out and bought SMA 50 (Ohm) LLC Coax
I think that's where we are at.
LET THE TESTING BEGIN
