Is that only me who find it anoying that in Cursor menu the measured DeltaX value changes when you change timebase/H wheel?
I was inspecting the HTI HT-H8 IR camera (which is true a HT-301) where i found 4 interesting pin holes that looked like a UART port. I hook up the SDS2504X HD and watched the signals to catch the baudrate in first place.
When i set timebase to 1.00µs/div to set cursors most accuratly i get 8,68µs DeltaX value which means it uses a baud rate of 115200. When changing timebase, at 10.00µs/div, the DeltaX show 8,7µs and changes to 9µs when changing timebase to 100µs/div.
Changing timebase further to 1.00ms/div, the DeltaX show accurate 8,680µs. Is this a bug? Can i change that behavior somehow?
I save screenshots for documentation and i want the correct value at any timebase.
