Author Topic: Siglent SDS2000X HD, 12bit, 2GSa/s high definition oscilloscope serie.  (Read 344803 times)
0 Members and 26 Guests are viewing this topic.
Offline 2N3055
  • Country: hr
Re: Siglent SDS2000X HD, 12bit, 2GSa/s high definition oscilloscope serie.
« Reply #300 on: September 07, 2022, 09:59:21 am »
2N3055 no specific concerns but I do think about things like is the UI user friendly (having not own siglent before) I find the mso5000 a bit clunky sometimes I've also had it crash.I spent a long time chasing a signal when the scope wasn't triggering because of a bug https://youtu.be/Fg9eL_EKgmE
Aha, well those are more specific...  ^-^
U/I is "inspired" with LeCroy Touchscreen concept. New Tektronix touch screen scope have similar logic.
You have menu on top, and status bar on bottom. On right you have popup vertical menu where you set parameters. When there is more data to show it pops up a larger window on the screen where you set stuff.
You simply run it as you would a tablet PC with a scope as dedicated application. Of course, there are knobs for most used stuff.
Layout is quite logical.
As for stability, in 6 months I had it I never had it crash on me. Similarly, SDS6000H12 never crashed, in a year or so.
Stability in that regard was excellent from the beginning of beta test period. There are not known bugs with triggering or like that I know of. Even if something was found it would get fixed quickly. That would have high priority.
One thing that surprises people is how acoustically quiet it is. It has fan but you wouldn't know if it weren't for a fan test on powerup.....
It is also very compact  while still having large screen. Keysight 3000T has tiny screen in comparison.
Also, trace is so thin, looks like a nice trace on analog scope. Courtesy of low noise inputs and 12 bit converters.
I must say that next to powerful SDS6104H12, 3 Picoscopes and MSOX3104T, SDS2000X HD gets a lot of use....
Very nice instrument.
The following users thanked this post: jord4231
Offline kripton2035
« Reply #301 on: September 07, 2022, 04:45:52 pm »
trigger is almost pulled here too... still waiting for some "public" method to unlock it but ...
Offline jord4231
« Reply #302 on: September 07, 2022, 08:13:36 pm »
After reading every post in this topic (many times  :-DD) , I don't think that will be a problem  ;)
Offline Martin72
  • Testfield Technician
« Reply #303 on: September 07, 2022, 09:05:26 pm »
I´m not so optimistic what "public method" concerns. ;)
(Kierkegaard)
Offline jord4231
« Reply #304 on: September 07, 2022, 09:31:21 pm »
Wait and see I guess. The low noise and 12bitys are enough value in it for me alone.
Offline Martin72
« Reply #305 on: September 07, 2022, 09:42:07 pm »
The 12 bit was for me the main reason to buy it.
As a nice "gift", it comes along with a very superb building quality.
(Kierkegaard)
Offline jord4231
« Reply #306 on: September 09, 2022, 03:33:23 am »
Pulled the trigger, I'm now a SDS2104X HD owner waiting for delivery    :-+ :-+ :-+
a teas session might be in aid  :scared:
The following users thanked this post: 2N3055, TopQuark, Martin72
Offline Martin72
« Reply #307 on: September 09, 2022, 05:15:33 am »
Number 3.... ;D
You won't regret it.  :-+
(Kierkegaard)
Offline TopQuark
  • Country: hk
« Reply #308 on: September 09, 2022, 10:09:11 am »
Late reply, but welcome to the club. I love my SDS21504X HD, it is compact, responsive and reliable, a joy to use for sure.
The following users thanked this post: Martin72, jord4231
Offline tomud
« Reply #309 on: September 09, 2022, 05:17:01 pm »
Why am I reading this  :-// I am more and more tempted to buy the SDS2000X HD version  :-DD
Although the SDS5000X version is also tempting, but here the equipment is probably different in higher versions and it is impossible to make a 1GHz version :-\
It is a pity that there is no SDS6000 H12 Pro version in Europe - although such an expense would probably lead me to bankruptcy :palm:
You must take a break from reading this forum, my home budget may not be able to withstand it  :scared:
« Last Edit: September 09, 2022, 05:20:10 pm by tomud »
For every complex problem, there is a solution that is simple neat and wrong...
Offline jord4231
« Reply #310 on: September 09, 2022, 08:44:20 pm »
My budget is decimated for the next 4 or 5 months  :'(
Meh it will be worth it. My only regret was placing the order on a Friday  :-DD
I also purchased a current probe when I purchased the scope.
Guess I can read the manual this weekend :)
Offline Martin72
« Reply #311 on: September 09, 2022, 08:56:55 pm »
Which current probe ?
(Kierkegaard)
Offline Martin72
« Reply #312 on: September 09, 2022, 09:06:49 pm »
Here a little clip from me, showing the scope on my desk:
https://www.youtube.com/shorts/pQaO7TtJC80
(Kierkegaard)
Offline jord4231
« Reply #313 on: September 10, 2022, 07:35:12 am »
Just a Micsig CP2100B 2mhz
Offline tomud
« Reply #314 on: September 10, 2022, 07:47:04 am »
Probably it will be the same for me, it is almost two of my entire salaries...  :phew:
Martin, can you tell me what the real height of the oscilloscope is, I wonder if it will fit or will I have to move the shelves. As you can see in the photo, I have some 28cm space between the shelves...
« Last Edit: September 10, 2022, 07:48:39 am by tomud »
Offline Martin72
« Reply #315 on: September 10, 2022, 07:52:19 am »
23.6cm....
Micsig2100B
Not the badest choice.  :-+
(Kierkegaard)
Offline jord4231
« Reply #316 on: September 10, 2022, 07:59:16 am »
I got quite a sizeable discount buying the probe and scope together $500 AUD off!
I found a cool bamboo monitor stand today. Fantastic for a scope the SDS2000xHD will be going on it
The probes and some accessories fit in the draw.
Found this at Kmart
I've just found out I've got the following week off work, Loads of time to play with the new scope when it turns up
Offline jord4231
« Reply #317 on: September 12, 2022, 01:43:47 pm »
Well It arrived today.
I made a quick video on it https://youtu.be/rvn4mzTLlnA
It seems to have a loud power supply when in standby I've included that in the video.
Anyone else experienced this?
The following users thanked this post: Electro Fan
Offline Martin72
« Reply #318 on: September 12, 2022, 06:01:03 pm »
Hi and congrats to your new scope.
Yes, when everything else in the working chamber is off and silent, I can hear a whining sound when scope is not on.
It comes from the internal supply from meanwell, when it got not enough load.
Possible solutions could be by glueing the coils or put an additional loadresistor on the output.
But this must be done by siglent or they allow it to do without loosing warranty.
When it´s really too loud for you - Me, I´m always switch it hard off when not in use.
Best solution would be a hard switch instead of the standby thing.
Nearly every brand got it today and I still don´t know why... 8)
At which time ?
EDIT 8h43pm:
the supply of the scope
« Last Edit: September 12, 2022, 06:43:45 pm by Martin72 »
(Kierkegaard)
Offline tv84
  • Country: pt
« Reply #319 on: September 12, 2022, 08:13:49 pm »
If I had something like that in such device, I would REALLY be pissed off!!!
Offline Martin72
« Reply #320 on: September 12, 2022, 08:28:36 pm »
Me too if I would put an external microphone on it..
(Kierkegaard)
Offline jord4231
« Reply #321 on: September 12, 2022, 09:23:19 pm »
Yep some SMPS make noise luckily nothing else in my lab this much. This one is just louder when not under load. It's loud enough to hear over the server  :palm: anyway yes I won't be leaving it in standby. I thought you owned one TV84?
Offline tv84
  • Country: pt
« Reply #322 on: September 13, 2022, 11:39:44 am »
I wish. If you send me yours I'll promise I'll buy a bamboo stand for it!  :) (and some ear plugs)
Offline Bad_Driver
Offline 2N3055
  • Country: hr
« Reply #324 on: September 15, 2022, 10:48:55 am »
The competitor shows up - now with US prices.
https://www.rigolna.com/products/digital-oscilloscopes/hdo4000/
https://www.rigolna.com/products/digital-oscilloscopes/hdo1000/
With due all respect, not really a competitor..
It has 12 bit specified and that is all.. We have yet to see how it works.
It is also missing a lot of stuff.. Let's see how it works first, before passing opinions..
The following users thanked this post: nctnico, Martin72
