Author Topic: Siglent SDS2000X HD, 12bit, 2GSa/s high definition oscilloscope serie.  (Read 352912 times)
gburdzin (+ 1 Hidden) and 1 Guest are viewing this topic.
Offline Performa01
  • Country: at
This is -50dBm from AWG, through 70dB of attenuation.
200Mhz BW limit to limit folding noise from higher frequencies.
So we are talking about a signal of -120 dBm = 224 nVrms = 632 nVpp.
Maybe you could try with the SDS7404A, a proper BW limit set to 60 MHz and 32 Mpts FFT ;)
The following users thanked this post: egonotto, Bad_Driver
Offline 2N3055
  • Country: hr
You know I will!
But first:
« Last Edit: Yesterday at 02:08:48 pm by 2N3055 »
Offline 2N3055
  • Country: hr
And same thing 7000A
16MPts and 32MPts FFT
« Last Edit: Yesterday at 02:33:36 pm by 2N3055 »
The following users thanked this post: egonotto, KungFuJosh, Bad_Driver
Offline Bad_Driver
This is really fun!
The following users thanked this post: egonotto, 2N3055, Grandchuck, KungFuJosh
Online ebastler
I'd say that qualifies as "in the ballpark"!  8)
The following users thanked this post: Bad_Driver
