Author Topic: Siglent SDS2000X HD, 12bit, 2GSa/s high definition oscilloscope serie.  (Read 363614 times)
Offline 2N3055
  • Country: hr
Re: Siglent SDS2000X HD, 12bit, 2GSa/s high definition oscilloscope serie.
« Reply #1200 on: August 09, 2024, 03:21:54 pm »
Thank you both for your answers!
Then I guess the question is, if I can do Analysis -> Counter with statistics, is there any reason to bother with using the Measure Freq(C1) option?
Measure:Freq will follow the signal in capture.
Set awg for FM and do measurement on longer capture. Then set Track on Measurement:Freq.
Also with measurements you can measure on 4 channels at the same time...
The following users thanked this post: egonotto, KungFuJosh
Offline tv84
  • Country: pt
« Reply #1201 on: August 09, 2024, 03:22:48 pm »
PS: Why do I even bother? Performa already answered....  :-DD
Essential for me. Performa's was beyond my understanding.  :)
The following users thanked this post: egonotto, 2N3055, KungFuJosh
Online KungFuJosh
  • TEAS is real.
« Reply #1202 on: August 09, 2024, 04:16:46 pm »
Definitely both answers together were helpful for me. 😉
Offline Performa01
  • Country: at
« Reply #1203 on: August 09, 2024, 06:06:53 pm »
Well, there might be some reasons why you still use frequency measurements - here are a few:
  • You can have as many frequency measurements in parallel as you like (up to the maximum in the respective measurement mode).
  • You can measure the frequency not only of the input channels, but also in zoom, math, reference and memory channels as well.
  • You can have a histogram in the measurement statistics.
  • You can use Trend plots to observe the developement of the measurement value over time.
  • You can have Track plots for showing the distribution of frequency (or any other time-related measurement) within a single record. You can do FM-demodulation with that.
Offline 2N3055
  • Country: hr
« Reply #1204 on: August 09, 2024, 07:48:23 pm »
What he said... :-DD
Resistance is futile... :-+
« Last Edit: August 09, 2024, 07:50:38 pm by 2N3055 »
Offline p_mint
« Reply #1205 on: August 23, 2024, 06:47:17 pm »
Hello everyone,
thanks to the people here I became the owner of sds2kxhd. I will post the result from my unit in several posts. All channels, (1 of 3).
« Last Edit: August 24, 2024, 06:07:03 am by p_mint »
The following users thanked this post: egonotto, Grandchuck, ozkarah
Offline p_mint
« Reply #1206 on: August 23, 2024, 07:24:39 pm »
Channels 1 and 3, (2 of 3).
« Last Edit: August 24, 2024, 06:06:08 am by p_mint »
Offline p_mint
« Reply #1207 on: August 23, 2024, 07:28:23 pm »
Channels 2 and 4, (3 of 3).
« Last Edit: August 24, 2024, 06:04:12 am by p_mint »
Offline Costas07
« Reply #1208 on: September 05, 2024, 09:02:09 pm »
Finally, after one month and a half of waiting got delivered the order so I'm a new happy owner of SDS 2204X HD.
The build quality is indeed good. Still exploring it ...
The following users thanked this post: egonotto, tautech, KungFuJosh, Martin72, ozkarah
Offline Bad_Driver
« Reply #1209 on: September 06, 2024, 10:54:47 am »
I watched Dave's new video on the hyped 20k€++ HP.... sorry Keysight HD3 and was curious to see what the little SDS2000X HD will deliver with the same settings in the low signal test.
Dave's video at 37:17
https://youtu.be/amxBD2WzEA4?si=ce1IAdheSIsO_twb
Settings (from the video):
2 mV/Div, 2 us (I took 10 us to achieve same Pts/sec for FFT), 15uV, 50 MHz, -12 dBm Attenuator.
Also my first chance to present my new acquired Marconi/Aeroflex 2031 RF-generator.
Seems to come from the Bundeswehr (German Army), it has Pulse modulation for radar testing.
The Gen has only 300 power on hours  :-DD and was not expensive.
„Everything must be made as simple as possible. But not simpler.”
― Albert Einstein
The following users thanked this post: kripton2035, Performa01, egonotto, tv84, 2N3055, Mortymore, Grandchuck, KungFuJosh, Martin72, Costas07
Offline Costas07
« Reply #1210 on: September 06, 2024, 12:47:02 pm »
Please could someone help with "unlocking" some options on SDS 2204X HD ?
Offline tv84
  • Country: pt
« Reply #1211 on: September 06, 2024, 02:04:29 pm »
Could you repeat also with 10uV and/or 2uV, as Dave did (if I remember well...)?
Offline Bad_Driver
« Reply #1212 on: September 06, 2024, 04:51:36 pm »
Quick and dirty, must be checked. See attached. No additional attenuators.
#1 1 uV RMS (-107 dBm)
#2 -110dBm = 0.7 uV (RF Gen accepts only dBm when Vrms < 1 uV) but with 500 uV/Div
« Last Edit: September 06, 2024, 05:15:44 pm by Bad_Driver »
― Albert Einstein
The following users thanked this post: Performa01, egonotto, tv84, Mortymore
Offline tv84
  • Country: pt
« Reply #1213 on: September 06, 2024, 05:26:30 pm »
Choose the option:
1 - Your generator is good.
2 - Your scope is good.
3 - Both are good.
The following users thanked this post: Performa01, egonotto, KungFuJosh, Bad_Driver
Offline Martin72
  • Testfield Technician
« Reply #1214 on: September 06, 2024, 07:46:33 pm »
1+2 = 3
I'm tempted to recreate that.
But I don't think I'll be able to do it because of the higher bandwidth, we'll see.
(Kierkegaard)
Offline Martin72
« Reply #1215 on: September 06, 2024, 08:51:57 pm »
For the “Chapter” 37:10 - 14bit ADC TESTED
He had only used one setup.
(Kierkegaard)
Offline Bad_Driver
« Reply #1216 on: September 08, 2024, 10:57:01 am »
I went thru the HP/KS HD3 datasheet (see first small picture) and tried to repeat measurements.
I used (nearly) the same settings and  it is interesting what I can achieve with the SDS2000 HD. Not bad!
Than I was looking for the limits what is possible.
RF Gen: 100 MHz, 1 uV RMS (2.8 uVpp)
SDS: 100mV/div (!!!), same FFT settings as before.
Now I need an explanation: 100 mV/div means about 1 V measurement range, 12 bit resolution means about 250 uV resolution. Why it is possible to find the 100 MHz peak of 3 uVpp in the FFT?
― Albert Einstein
Online gf
« Reply #1217 on: September 08, 2024, 11:23:25 am »
1) There happens to be enough dithering noise, and 2) due to the large number of points, you get sufficient processing gain.
The following users thanked this post: egonotto, 2N3055, Bad_Driver
Offline Performa01
  • Country: at
« Reply #1218 on: September 08, 2024, 03:19:28 pm »
You're not really seeing it. The SDS2000X HD quite obviously happens to have a spurious response at exactly 100 MHz. This is why it often is a good idea to avoid such straight frequencies for critical tests. Even better: check in advance with a zero signal.
Dead giveaway: the level of a 1 µVrms signal should be -107 dBm, which is far below the noise floor, as expected.
You see -98 dBm, which corresponds to 2.8 µVrms. With a gross error like this, you should immediately get suspicious.
In principle, you could measure such low signals if you had a much longer FFT available - unfortunately, 2 Mpts won't be enough. For the 12-bit machines there is definitely enough (particularly LF) noise for dithering, so that you can exceed the 73 dB dynamic inherent to a 12-bit system even in the most insensitive 100 mV/div setting. It is differeent with just 8 bits.
The following users thanked this post: egonotto, Martin72, Bad_Driver
Offline Bad_Driver
« Reply #1219 on: September 08, 2024, 05:57:46 pm »
Thanks Performa01, my doubts seems to be right!
I will look into this tomorrow again.
Do you have a solution for my question regarding the possibility to calculate rtHz power density from my post
https://www.eevblog.com/forum/testgear/siglent-sds3000x-hd-and-upgraded-sds1000x-hd/msg5633465/#msg5633465
Thanks!
― Albert Einstein
Offline 2N3055
  • Country: hr
« Reply #1220 on: September 08, 2024, 06:35:31 pm »
Thanks!
Sorry, no way to do it on the scope at this moment.
The following users thanked this post: Performa01, egonotto, Bad_Driver
Offline Bad_Driver
« Reply #1221 on: September 09, 2024, 07:04:51 am »
With the advice of Performa01 in mind I did the measurement again at 97.7 MHz.
The limits seem to be around 3uV RMS for a signal to be found with the settings.
Below are spurious signals (yes, @100 MHz as well).
See pictures attached. Thanks again for the lesson learned.
― Albert Einstein
The following users thanked this post: Performa01, egonotto, Grandchuck
Online gf
« Reply #1222 on: September 09, 2024, 12:15:35 pm »
Since you have used only 500k FFT points, there should still be room for an improvement of about 2x .
Offline 2N3055
  • Country: hr
« Reply #1223 on: September 09, 2024, 01:49:59 pm »
This is -50dBm from AWG, through 70dB of attenuation.
200Mhz BW limit to limit folding noise from higher frequencies.
Offline Bad_Driver
« Reply #1224 on: September 09, 2024, 01:54:07 pm »
ok, here we go with 2MPts FFT.
― Albert Einstein
