Successfully applied hack to transform the SDS2202X-E to 2352X-E, thanks to information in the blog!
After PM from one user, I realized that a detailed upgrade procedure wasn't available. So I am attaching a suitable Python 3 script, containing instructions. ![Popcorn :popcorn:](https://www.eevblog.com/forum/Smileys/default/EatingPopcorn.jpg)
I used only '300' option.
Hi, thanks for the script.
So you used the "300M" option to get the upgrade to 2352X-E with 350MHz bandwidth?
If possible, could you check what your scope is displaying as "Product Type" in (press Utility button) > "System Status" menu after applying this patch?
What is the model reported by
*IDN? SCPI command?
Thank you!
