Author Topic: OLED display Agilient U1253B meter - recompense for repair  (Read 1922 times)
Offline pwrtrnxTopic starter
« on: October 26, 2020, 05:43:06 am »
Display repair for Agilent U1253B multimeter  ( 6 year old OLED display faded away )
Hello all,  I have one of these ( my company does )  -  I would be quite happy to pay a good figure to anyone who can perform a quality display replacement  -  ideally with a very similar LCD display so that further work is not necessary,  i.e. the repair will last.
Failing that a newer OLED display for an effectively interim repair ...
I have seen the other posts on here as to how to go about it  -  but they appear at first glance to be technically not quite complete or fulsome  -  some efforts give a reversed display etc.
I look forward to genuine replies from possibly amateur, semi-amateur or more professional people  -  who have the requisite ability.
Offline uski
Re: OLED display Agilient U1253B meter - recompense for repair
« Reply #1 on: October 26, 2020, 07:35:51 am »
There are very complete information with this post, along with an offer to get PCBs for very cheap and part numbers :
https://www.eevblog.com/forum/testgear/replacing-oled-screen-on-an-agilent-u1253a-multimeter/msg3085696/#msg3085696
If you do not want to do it yourself, I suggest you ask in that thread if someone is willing to do it for compensation.
Offline uski
« Reply #2 on: October 26, 2020, 08:20:12 am »
Okay, good luck.
« Reply #3 on: November 30, 2020, 07:58:28 am »
Hi all,  successfully repaired the OLED display  -  many thanks to all the pointers to TAOBAO and other top tech tips w.r.t. soldering the thin flex pcb connectors ...!
