Author Topic: Siglent SDG1025 Square wave question  (Read 1334 times)
Offline tip29Topic starter
« on: March 21, 2018, 11:34:08 pm »
Hi all,
I just bought Siglent SDG1025 function generator mainly to generate pwm signal for DC/DC converter (I am trying to learn DC/DC converters).
I found its output @ 4Vpp square wave has 1V overshoot and ringing. I have attached a picture below. Is this acceptable?? Looks terrible to me.
Also, the falling edge has 20ns jitter. I read about the jitter problem on some posts and the solution was to use pulse function. But the ringing on pulse function is even worse.
I am just a hobbyist and this is my first function generator. I feel like I should have just gotten a used agilent.
Thanks.
Offline DaJMasta
    • medpants.com
Re: Siglent SDG1025 Square wave question
« Reply #1 on: March 21, 2018, 11:39:10 pm »
Are you using a normal scope probe?  Have you tried connecting the BNC directly?
This is common because of the extra inductance of the probe's ground lead making a loop in the circuit and doesn't necessarily mean that it's actually being generated - it could be entirely an artifact of the way you are probing the signal.
« Reply #2 on: March 21, 2018, 11:51:10 pm »
I had BNC to minigrabber cable from the SDG connected to the probe of the oscilloscope.  The ringing diminished while probing BNC of the SDG directly.
I am stupid. :D
Thanks!
« Reply #3 on: March 21, 2018, 11:53:25 pm »
As DaJMasta says, your probing/measurement techniques are the reason for this.
All Siglent AWG's are designed for 50 \$\Omega\$ impedance loads so to display the waveform accurately you must terminate into a 50 ohm load. Try a BNC cable and a BNC 50 ohm feed through.
Another trap for young players is the Load setting in the Utility menu. Hi-Z or 50 ohm selection ONLY adjusts the output voltage to match the intended load and as mentioned above the output impedance is always 50 ohm.
Some stuff seen @ HQ cannot be shared.
Offline DaJMasta
    • medpants.com
« Reply #4 on: March 21, 2018, 11:54:04 pm »
I am stupid. :D
Thanks!
It's been a while, but I've done it too.  No worries  :P
