Author Topic: Siglent SDS2000X and sigrok?  (Read 1634 times)
Offline PolarCrewTopic starter
« on: March 21, 2018, 11:20:44 am »
Hello,
Is there SDS200X owners that have used sigrok?
My question is: Does it support digital channel acquition of logic channels over USB ?
Maybe it's my bad english but i don't know if they say on sigrok wiki that there is old version of SDS2000X that doesn't support digital channels capture from sigrok. Or do they mean that SDS2000X is old serie that doesn't support digital channel capture.
This quote is from sigrok wiki:
"The older series SDS2000X Logic Analyzer function does not support acquisition of the LA channels over VXI or USB. Due to flash memory program limitations the code for this function does not fit. Its not clear if newer "E" scopes will come functionality for the SDS2000 series scopes."
https://sigrok.org/wiki/Siglent_SDS2000X_series
And yes, I'm about to purchase SDS2000X model scope  ::)
Offline abraxa
  • Sigrok associate
Re: Siglent SDS2000X and sigrok?
« Reply #1 on: March 21, 2018, 11:46:39 am »
If you have a github account, I suggest you open an "issue" with marchelh's libsigrok fork: https://github.com/marchelh/libsigrok/issues
He's the one who added support for the scope series and also wrote the wiki page that you're refering to. I agree by the way, the wording could be clearer.
« Reply #2 on: March 21, 2018, 12:24:12 pm »
Thank you!  :-+
« Reply #3 on: March 21, 2018, 05:36:07 pm »
WRT Sigrok.
From a contact in Siglent:
-   Our current scopes only return Analog Channel data
-   The 1X, 2, and 2X all work with Sigrok (but only Analog)
-   Soon, we hope the 4 channel XEs will be able to return digital data, too
..........SDS2000X that doesn't support digital channels capture from sigrok
Correct, they don't.  :(
Some stuff seen @ HQ cannot be shared.
